So before i put some pics up from last night I will just finish off the rest of the car build.
Once the clutch went, i brought a os giken single plate & flywheel.
Since then i have done a few more track days and drift pracs
The only real changes to the car i have made have been suspension tuning, and a lower lip.
Recently i changed the surge tank and radiator. I have also made up some sump protection and a better upper rad support.
So yesterday i had a bit of a meeting with some tyres at turn 1,
Came in for a bit of a flick into turn 1
After the the car stopped, there was absolutely no steering input, the boss kit was slipping on the steering shaft.
Im not 100% sure but the car really didn't feel nice once i gave it the first flick.
Im guessing the nut came loose, and that caused obvious loss of control.
Once we had a look over everything else, and fixed up the bosskit (with a bit of coke can) went out again in the later sessions.
Damage really wasnt too bad. both sidelights, grill, lower lip, bumper bracket. bent both guards (bent back ok) and bent all my cooling panels.
Im booking the car in for a full cage over the next few weeks.
