i just machined the front pulley off my 4age crank pulley. no problems
im sure there are aftermarket pulleys tho, you can even buy them as a kit with the alt and waterpump pulleys too
hey guys,
As i dont run p/s or a/c in my 86 ,and i would like a bit more clearance between the crank pulley and my fan shroud.
Is it possible to get these (a/c & p/s)removed off the pulley by machining ?
Or does anyone know of a aftermarket single pulley as i only need to run the water pump.?
Any help would be greatly appreciated.. Shaun
I have a stock rwd harmonic balancer with the front pulley machined off..no longer required due to going to a t3 solid edis pulley..would sell it I you wanted itmessage me
MY AE86 BUILD
Hey lazy have you realized all the legit players rock 2 ltrs and gone to a sr20?? He he
Only problem I could see with machining down a stock one is if they have removed material to balance it on the part you take off
But sr have a huge after market support so I'm sure single lightweight pulley would be easy to come across
JJ
LOL...excuse my comment bloke...didnt pay any attention to thread title...
MY AE86 BUILD
has your toyota ones got rubber in them?
From what ive read so far their calling it a balancer, but i cant see the harm in making it lighter if im putting a lightened flywheel at the other end?
can anyone suggest someone in the brisbane area to machine it down?
good engine shop will be able to balance it if your worried, lol reliable sr's you funny man
Got it sorted. Getting the front pulley machined off and checked so it's balanced when spinning.
Thanks guys.
