Results 1 to 6 of 6
Thread: Fuel system wiring
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Fuel system wiring
    Hello all,
    First of all I want to say sorry for asking more questions about fuel setup wiring, as I know it's been covered alot.
    im wiring in my fuel pumps this weekend and I want to make sure I have it right. Below I have drawn a diagram of how I think it should be wired in, I want someone to clarify if it is right or wrong. It is the usuall 4age into ke70. If I have it wrong can someone plz correct me
    Cheers guys
    [IMG][/IMG]
    Noooob
    I didn't check the numbers were correct on the relay... But the diagram is definately correct
    May 2010
    Adam
    St George
    Sweeeet. Cheers
    Mt Macedon
    That's perfect (and a nice diagram) as far as I can see (I don't know relay pin numbers or COR wire colours), except for the STA signal to the COR.
    The ECU STA is an input to tell the computer you are cranking. For the COR, take a "direct" starting signal, for example from the key barrel. Of course if you have the key barrel STA wired to the STA pin on the ECU then you can splice into this and my point becomes a bit irrelevant. Just don't connect the ECU pin to only the COR.
    Noooob
    Moved to tech articles...
    For those interested in a map wiring diagram, grab the FC pin off the ECU and connect that instead of the AFM and you are done.
    May 2010
    Adam
    St George
    All makes perfect sence now, pretty simple when u draw it out, just gotta stop thinking about before I confuse myself again!!
    Thanks guys.
  1. Fuel system, Surge tank, Fuel pump ect
    By stixy in forum Cars or Parts Wanted
    Last Post: 19th February 2011, 03:23 PM
  2. Alarm System Wiring, Few Q's
    By tc-rolla in forum Technical - Questions
    Last Post: 24th March 2010, 07:24 AM
  3. fuel system setup
    By fatke in forum Cars or Parts Wanted
    Last Post: 17th August 2009, 10:48 PM
  4. Fuel System
    By lo_rolla in forum Technical - Questions
    Last Post: 22nd June 2008, 07:40 PM
  5. fuel system info
    By loc33e in forum Technical - Questions
    Last Post: 14th May 2008, 10:03 PM
