The one thing I want/need to know with this hybrid motor is which oil pump to use/is best......
I'm going down the 20v (silvertop) route, and I'm going to have it redlining at around 8-8200 or so... (properly built of course) now, I'm picking up a new 7afe oil pump which has been ported' (thanks 7OXIN) just unsure if I should use that or the pump off the 20v?
If I use the 7afe pump will there be any issues in regards to those rpm's causing reliability issues? and using the 20v timing gear or do I stick with the 7afe one here also? (for the sake of timing issues associated with the swap)?
same for crank pulley?
is it all compatible and at the right off set... I'm guessing I just use all the 'GE' pulleys... is this correct...
knowledge is power...
