Results 1 to 10 of 10
Thread: lightweight crank pully
    mark
    central coast
    Default lightweight crank pully
    could you use a solid lightweight crank pulley on a 4ag? i was thinking of trying to make one on a lathe but im not sure if you need the "rubber" bit in between the pulley and the centre piece. or if this is not needed
    Jason
    Southern Suburbs
    Technically, the pulley is the harmonic balancer. I have seen the SS works aluminium pulley and it is not modified for balance. I run a ringle row machined 4AG pulley and have had no balance issue.
    The result of this is that I will be making a smaller pulley in place of bigger alt and water pump pulleys.
    Also look at the T3 ones. No balance/machine holes last time I looked.
    mark
    central coast
    so are the t3 ones a single solid piece or two piece like the standard one?
    Jason
    Southern Suburbs
    pic are there
    mark
    central coast
    they look single. thanks for that
    Tan
    West
    you could machine down a 16v rwd pulley and it would be ~1/2 the original weight
    Jason
    Southern Suburbs
    They are not half the weight as the rear section is almost solid- go and look at the pulley.
    And in fact, the RWD pulley has a smaller pulley size for the front section.
    Tan
    West
    Hence why I put a '~' sign to indicate its approximation...though I agree with you its probably even 1/3 but thats still decent amount relative to itself. At least that way, the dampening rubber can be retained.
    i have a single row lightweight rwd pulley that i may sell for around the $150 mark if anyone is interested in it...have decided that standard RWD pulley is a better option for me...pm me for further info if ur interested
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    i have been on the toymods website and this is what a bloke is thinking of doing a group buy for these are a custom fully alloy and are very good for high reeving/power engines im thinking of getting 1
    the dyno pull to 300rwkw
  1. 4AGE Corolla AE86 Lightweight Crank Pulley
    By belstaff in forum Ebay Items - My Stuff
    Last Post: 4th January 2013, 10:47 PM
  2. Replies: 11
    Last Post: 28th May 2011, 02:24 AM
  3. Lightweight crank pulleys....
    By DRFT - 86 in forum Technical - Questions
    Last Post: 29th May 2008, 10:46 PM
  4. 4age Crank Pully Bolt
    By newby86 in forum General Topics (No Technical Questions)
    Last Post: 5th February 2006, 08:50 PM
