Results 11 to 20 of 27
Thread: AE86/KE70 rear coilovers
  1. #11
    Aug 2011
    Jason
    Nsw
    West Sydney
    thanks, next time lose the attitude. I purely said it because everyone would have told me "ohh its a daily why dont you just get falcon springs, that will be too stiff for the street"
  2. #12
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Hey hey hey
    you started with the attitude of dont tell me rah rah rah i know best.
    You've been shown two options of exactly what you want and a couple other options. Now have a look into what you need and come back if you have anymore technical questions where you'll be willing to accept constructive feedback.
  3. #13
    Coilovers in the rear are far from the best option...I suggest further research into the topic rather than assuming what works in a Nissan will work in a corolla...
  4. #14
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    plus 1
  5. #15
    Senior Member daltrim's Avatar
    Dallas
    Ashmore
    I have paradise racing coilovers in the back pf my ke and it is awesome, easy to install and plenty of adjustment
    I will finish ,One day.
  6. #16
    Veteran shift_rook's Avatar
    SE Burbs
    Firstly you mention you know coilovers are stiffer, well they're not, whether it's a coilover or not doesn't change the spring or damping rates. Secondly there isn't enough clearance to fit a proper size damper in there with then a spring over, so manufacturers use a much narrower damper to fit it all sacrificing control. Thirdly, stiffer doesn't always mean faster, if the setup is too stiff you'll have a much earlier loss of traction. If i could supply a rear coilover that bolts in and still keep the performance there i would.
  7. #17
    ^^^ says the bloke who works in a high performance suspension related business...take his information/opinion seriously...his helping with good information rather than cashing in on's quick buck (not saying anyone here is, but generally it's the case with people offering substandard products)
  8. #18
    Senior Member JinxD's Avatar
    Ash
    Has anyone used the mcn rear Coilovers? That looked like a good bit of gear
    GhettoGarage.org
    Quote Originally Posted by mild seven View Post
    i cant stand "JDM faggots" (people outside of japan who are MORE JDM than people in japan)
  9. #19
    I bought them and on sold them to another bloke... Build quality is quite good... Made for mcnsport by AVO with nearly identical shock specs to TRD blues. Very much the same style as the GAZ setups that are also floating around. in all honesty I would most likely still have them if I hadn't Ben convinced by the shockworks guys...of which I'm still yet to purchase lol
  10. #20
    Ash
    Oh you!
    GhettoGarage.org
  1. Replies: 7
    Last Post: 15th August 2011, 02:44 AM
  2. ae86/ke70 rear coilovers damper/height adjust
    By ae8620v in forum Car Parts For Sale
    Last Post: 3rd February 2011, 07:52 AM
  3. ae86/ke70 rear coilovers damper adj, rays mesh
    Last Post: 29th January 2011, 11:22 PM
  4. Rear coilovers - AE86/KE70
    By GOODY in forum Cars or Parts Wanted
    Last Post: 20th May 2010, 06:44 PM
  5. rear 8kg springsor coilovers ke70
    By ke_70 in forum Cars or Parts Wanted
    Last Post: 18th March 2009, 09:39 PM
