Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 11 to 20 of 112
Thread: newbie ae86 build rb20det motor swap
  1. #11
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    Deleted double post* my bad
  2. #12
    Gone
    Joel
    Picton
    Just a note ... The SR makes more power and torque from factory then the RB20det.
    Your SR complete without box is around the 150kg mark
    Rb20 is up closer to 200.
    It's not just the physical weight, but where that weight is positioned.
    Don't get me wrong, not hating on you, just pointing out the facts.
    It's your car, if you want and rb 20.. Go to town
  3. #13
    Senior Member turn69up's Avatar
    Apr 2010
    Laurence
    Northside
    Judging by ur car history, this is going to turn into an abomination and up for sale faster than your SS
  4. #14
    Member spicer's Avatar
    May 2013
    brad
    nsw
    port macquarie
    Will keep you all possted removing the motor and box tomorrow hopfully then will lok at my options
    vk wagon-vr v6-vx berlina wagon-evo 5-s14.5-vs ss-holden lx8 adventra-ae86 current project fitting a rb20det in a ae86
  5. #15
    Gone
    Joel
    Picton
    If your dead set about fitting a straight 6, consider boxing the fire wall, set the motor as low as you can get it and as sensibly far back as you can, spacing the cross member after fitment may be required for better CoG.
    New tunnel would need fabing, then you just need to deal with shifter position.
    Of course none of this is absolutly necessary , just desired for optimal performance.
    The only benifit I can see is the rb 20 has a shorter stroke:bore
    So it will like to rev a little more.. Probably why is makes peak power 400rpm higher.
  6. #16
    Bah, I love these topics...purely thru not wanted to upset the bloke I'm not going to add my thoughts...
  7. #17
    Gone
    Joel
    Picton
    Ha, you could always draw a line in the sand John.
    I'd be interested to know what you think... Along as it doesn't entitle general statements like , "it's shit" or rubbish like "oh my cousins cousins mate, his sister put a triple turbo RB31 in her gemmi"
    You know the drill.
  8. #18
    May 2013
    brad
    nsw
    port macquarie
    im going to try my best to make it fit and work ive measured it and it seems like it should fit but wont know until I pull this motor out of the 86
  9. #19
    Senior Member Panda BVB700's Avatar
    Jul 2010
    Brenton
    Woodend
    im doing beams swap at the moment, but if you wanted to go diffierent have you thought about 3rz/turbo or even maybe something diesel probably not as worth it power wise but would be unique
    adm ae86 now one hell of a project
    ae71 small project
  10. #20
    Veteran Konakid's Avatar
    Henry
    Eastern
    If you are going to spend 20K all up to fuck up the handling balance of a corolla with a heavy straight 6 you can at least do it the decency of using a 1JZ.
    RT142 Estate.
    AJPS.
  1. Rb20det rebuilt fs or swap
    By 4agteke70 in forum Nissan Parts For Sale / Wanted
    Last Post: 29th January 2013, 12:20 PM
  2. wanted ASAP rb20det silver top motor S.A
    By slide wayz in forum Cars or Parts Wanted
    Last Post: 15th April 2010, 11:32 PM
  3. track rb20det sil80, sale or swap
    By scottae71 in forum Cars for Sale (Not Toyotas)
    Last Post: 25th March 2010, 06:57 PM
  4. Newbie with a newbie question
    By DjB in forum General Topics (No Technical Questions)
    Last Post: 22nd May 2007, 12:33 AM
  5. Newbie AE86 questions!
    By RunFree in forum General Topics (No Technical Questions)
    Last Post: 22nd October 2006, 04:25 AM
