Results 11 to 20 of 21
Thread: Ke70 Steering rack swaps - Achieving more lock?
  1. #11
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    I literally run xt130 lca, cut and shut knuckle, standard everything else and I hit chassis rail.
    The real question is, WHY do you need more lock?
  2. #12
    Pretty much the same in my ke70 also bloke...14x7 -/+0 and grabs rail...could get more but too much effort and no need
  3. #13
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    I've heard yarns of an aw11 rack being able to be modified to fit. Using a longer steering uni shaft from a supra or something. I can't confirm or deny this but as the others said. Jdi's, rack spacer and lcas n u should be pretty close to all ull need
  4. #14
    Veteran Skylar's Avatar
    Ken
    AE86 rack has 1 more tooth. 130mm total travel vs 120 from memory.
    Swapping racks is probably more effort than it's worth but that + machined rack ends and you'd be sweet. If you still want more, then get arms.
  5. #15
    Ken
    That's an America thing. Most corollas whether sr-5 or gts got ps and manual racks are rare. Aw11 rack swap is to get rid of ps and get more lock except instead of us putting ps arms in on a manual rack car, they're putting manual rack into a ps car. As far as I know, aw11 rack and manual ae86 rack is same.
  6. #16
    Sep 2010
    Craig
    Perth hills
    Ahhh righto yea that makes sense. Awesome
  7. #17
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i run just t3 arms in the inner hole.
    more than enough lock, and my wheels havn't fallen off yet.
    t3 arms arn't all bad, theyre just shorter arms with standard ackerman or same as oem arms
  8. #18
    Veteran AJPS's Avatar
    Lonsdale
    AW11 are the same racks im pretty sure
  9. #19
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    I wouldnt be running T3 stuff, just junk really not even made nicely. people choose the easy option of going JDI knuckles i highly recommend 'keto steering' knuckles out of NZ i run them on my car and the steering has never felt better. alot of lock running just a stock 70 rack no lock spacer zero signs of binding with steering rack mounts in the stock position.
  10. #20
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    How are JDI the easy option?
  1. KE70/AE86 Custom lock Steering arms
    By trikzlane in forum Car Parts For Sale
    Last Post: 15th May 2011, 07:11 PM
  2. Replies: 8
    Last Post: 26th August 2010, 09:00 PM
  3. Steering Lock/ Steering Rack Questions
    By bigm in forum Technical - Questions
    Last Post: 1st March 2010, 05:28 PM
  4. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
  5. Steering Lock - Quaife Rack, PS Arms, Tie Rods, Tie Rods Ends
    By SoKAR in forum Technical - Articles
    Last Post: 26th August 2007, 09:18 PM
Tags for this Thread
