I've Been thinking about this....just wondering why I'd need to use the W57 box & sa63 bell housing etc? I mean.....why couldn't I just use the std 6 speed box behind the beams? is it simply because of the shifter location or is there something else I'm missing?
I'd obviously need to fabricate a gearbox cross member and have a custom tailshaft made....and no doubt re wire plugs for reverse lights etc on the gearbox.......but is there a reason I can't do it that way? would the shifter come out somewhere in the back seat floor or something that's just not practical? lol......Just curious,cos I mean.....6 gears is gotta be better than 5 right?
and when I first started modding cars years ago I played around with a few datsuns.....and we had to cut new holes in the floors of 1600's and stanza's and make up crazy banana shaped cross members to run the stronger 240k gearbox's.....I kind of assumed it would be the same deal with this and far from impossible?
school me! haha
Anyway,I've been fixing the car up slowly over the past few weeks...removed the rusty mudflaps and the trims along the sills then painted bellow the doors black so it makes a clean line right through from the guards to the q/panels.....looks a lot better!
Also had a bit of rust I had to get rid of and clean up but its turned out pretty good.
otherwise no really exciting news sorry.....it's still stock as fuck atm,cleaned up the old 21r-c tho,and fixed an oil leak from the crank seal....only to find it was also leaking from the oil pump gasket,*Face palm*
been having second thought on not dropping the 22re in it tho......it's just a heaps cleaner engine,but I'm not to keen on swapping out fuel lines n looms etc for the efi so I'm thinking about fitting a 22r manifold & carb then swapping the dizzys for vacuum advance.
obviously an elec fuel pump too since the 22re doesn't have the cam lobe for the mechanical pump...I'm pretty sure that's all there is to it tho?
It'll just be a thrash around donk for the time being while I source parts etc for a conversion.......might put a cam in it and tinker around with the head tho,possibly slap a weber on an some extractors.....nothing too serious,but it should get me by for now.
Anyway.....I'll try to snap some more pics today,looked at the few that I have n thought "hmmm,looks kinda shitty" hahaha
Until then
Josh
