Page 19 of 27 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 LastLast
Results 181 to 190 of 263
Thread: Jarrad's AE86 resto project
  1. #181
    Veteran drift kid's Avatar
    Glossodia
    Fuhhh this car is going to be nicer than factory, everything looks so perfectly done! Those shots of the rear end are amazing
  2. #182
    Aug 2012
    Jarrad
    east
    So I haven't had an update in quite some time! I've been pretty busy.
    Finished uni, graduate next week (woo!) and have started a new job.
    Lately I've been working on the interior.
    I've fully fitted all of the carpet now, including the underfelt. It was an annoying job, but not that hard. Just lots of mocking up, placing, bolting, etc. Did it with my seat rails and bolts so that I knew how it would sit. I was initially a little disappointed that it wasn't 100% fitting, but then I looked closely at carpet in other cars (including my ke70) and they actually fit worse from the factory, ahhh the 80's.
ID:	34282Click image for larger version.
    I've been debating what to do with my door cards and rear seats.
    My front seats will be these Recaros, and I don't know whether to try match the fabric (source rear Evo 1 GSR seats for the fabric) or just ignore that. For now, I've fabric painted/dyed the door cards all black.
ID:	34287Click image for larger version.
ID:	34288Click image for larger version.
    I've fitted the roof lining and all plastic trims that support it, the kick panel trims, and whatever else I can put in before belts/seats. It's been vinyl painted as well, however it's a little streaky. Can't notice it at a glance, only when the light hits it at a certain point.
    My seat belts are all in terrible condition, so I need to make a decision.
    Option 1: find black seatbelts. New or in good condition (aware they're probably not ADR approved if from Yahoo. But I doubt they'd get checked)
    Option 2: Run it as a two seater, and install a harness bar. No need to get rear seats trimmed to match the front, and harnesses are probably going to cost the same as belts. Would then need to be engineered (which I was considering for the seats/coilovers just so it's a fully street legal car).
ID:	34286Click image for larger version.
    And in mechanical news, the engine bottom end is 100% complete. Crank, rods, pistons, clutch, lightened flywheel is all assembled and balanced as an assembly. Gotta drop some stuff down at the engine builder (who has also been really busy) and get started on the head.
    TL;DR
    Interior mostly fitted.
    To harness and lose back seats, or find seatbelts and re-trim?
    Engine progress still going.
  3. #183
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    Rear seats are only symbolic really, so I think unless you are going for a factory spec build they are kind pointless. Plus a mattress could probably fit in the back, perfect after a big night out so no one steals your car.
  4. #184
    Eddie
    Even if you go the harness route, you will still need ADR belts to get the car engineered. Any quick release turnbuckle harness is not road legal, you still need the normal 3 point belts as well. Klippan do new black belts if you want to go down that route.
    If the car is going daily duties, leave the rear seat in. It leaves the car more versatile. I have 2 baby seats in the back of the coupe... yes it's ridiculous.
  5. #185
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Yeah, its true mate, the other problem with harnesses is that they are not self tightening, which is also an ADR requirement. So even the harnesses like mine with the seatbelt style clip don't cut it
    Current Cars:
  6. #186
    Aug 2012
    Jarrad
    east
    Yeah, doing a bit more digging last night on modification laws and ADRs I did come across that.
    All seems a bit odd, but laws are laws, and even with engineers cert you can't get around needing retractable/original belts.
    Haven't heard of Klippan, so will check it out. Would be good to get some new replacements. Looked on Yahoo, but black ones are faded and a little shitty anyway.
    Are you running a Velo harness Robbo? I was looking at them and liked the seatbelt-style clip.
  7. #187
    Robbo
    Gippsland
    No I am running an OMP item that I sourced from a local store.
    Pretty good price for a brand new item from a reputable store. I had always thought that name brand harnesses were more expensive than that so in the past I had bought second hand ones of eBay only to find they were fakes
    Current Cars:
  8. #188
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I have Klippan belts in the back of my car Jarrad, you're welcome to come round and have a look at them and see if they're what you're looking for if you want.
  9. #189
    Aug 2012
    Jarrad
    east
    So I got my front belts fitted:
ID:	34313Click image for larger version.
    APV saftery products, part number:
    RH: k6508
    LH: k6507
    Brackets: K4425
    As happy as I could be with them. I would prefer that they had a top mount in the pillar as well, but all their books say don't attempt to recreate it, and just torque it all to spec.
    First side took ages to get it all working right, then the second side was done in 10 mins.
    Decided against harness route and stuff. Seeing as I need to run seatbelts with them anyway.
    For the trim panels, I just had to make a small cut to feed them onto the new belts and in position.
    Also visited the engine guy to drop a few bits off and have a chat. Happy with how it's coming along. He's done small touches like removing sharp castings to improve oil flow.
    Picked up a new water pump, thermostat, ordered a timing belt kit as well (thanks James!)
  10. #190
    Aug 2012
    Jarrad
    east
    The car has been a little bit on hold.
    Basically, I started fitting all the dash up, but want to test it all before putting it back together properly.
    To do that, I need to get some power to it all.
    To do that, I need to get a loom happening.
    To get a loom happening, it's probably best to just do it once I have an engine in and do it all in one go.
    Engine is still at the builders.
    So, to pass some time, I swapped my KE70 for a new toy.
    1987 G-Limited, factory supercharged (sc14 now) MR2, with optional t-tops (that leak, of course)
    It needs a bit of work, but it'll keep me busy.
    I've spent one full day on it and sorted out a bunch of stuff already. I reckon I'll pull all the carpet and stuff out over a weekend and clean it all up.
    Booked in for a major service on Friday. Has a starting and idling issue - once running it seems to be fine. Also has an oil leak.
  1. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 12th December 2010, 11:17 AM
  2. Jarrad's RA65
    Last Post: 16th October 2009, 12:09 AM
  3. My Project AE86
    By 4A-GE Power in forum AE86 Owners Forums
    Last Post: 2nd October 2008, 08:13 AM
  4. ADM resto
    By Judge Fudge in forum Cars or Parts Wanted
    Last Post: 14th August 2008, 07:21 PM
  5. Teddy's JDM Ke70 ground up-every bolt spec. Resto!
    By Teddy in forum KE70 / AE71 Owners Forums
    Last Post: 26th June 2008, 07:20 PM
