Page 24 of 27 FirstFirst ... 14 15 16 17 18 19 20 21 22 23 24 25 26 27 LastLast
Results 231 to 240 of 263
Thread: Jarrad's AE86 resto project
  1. #231
    Aug 2012
    Jarrad
    east
    Yeah, bright silver! Saw some nice bays in Japan and took a little inspiration off some of them. I want it looking quite neat but not suuuuuper show-car.
    Provided time and life stay out of it - not far! Trying to do something every day even if it's small.
    Today's task was to solve my water outlet problem. Turns out M16 to 5/8 elbows don't exist anywhere in the world. So had to fork out for some speedflow fittings. Also while I was at Pirtek I got a bit of longer braided hose to fit up my oil cooler. Thankfully it came with fittings.
ID:	36537Click image for larger version.
ID:	36538Click image for larger version.
ID:	36539Click image for larger version.
    My next major job is wiring. Also need to find a solution to hitting the clutch slave as I've checked a few different brands and they all seem to be similar in design.
  2. #232
    Aug 2012
    Jarrad
    east
    Been a while since an update has happened! (two months!)
    Car is getting pretty close now. Been learning and asking about wiring and it's pretty close now.
    Still a little lost on some loose wires I have.
ID:	36783Click image for larger version.
ID:	36784Click image for larger version.
ID:	36785Click image for larger version.
    Water system is fully completely minus one bottom hose clamp.
Name:	Photo 16-03-2016, 2 29 07 PM.jpg
ID:	36790Click image for larger version.
Name:	Photo 16-03-2016, 2 29 23 PM.jpg
    Fuel system mostly sorted as well, had the carbs on and off a couple times to check for clearances and stuff.
    Done pretty well minus the fuel pump - not yet sure where to mount it.
    Near the tank most likely unless I run a lift pump too.
Name:	Photo 10-03-2016, 3 30 45 PM.jpg
ID:	36789Click image for larger version.
    Tucked away!
  3. #233
    Aug 2012
    Jarrad
    east
    Filled the engine with oil... Learnt that it has an oil return on the smallport sump haha. Oil everywhere. Solved that with a secondary sump plug.
    Was also having issues with my extractors hitting my clutch slave. Bosch #JB4154 works as an alternative to the ADM/t18 clutch slave.
ID:	36828Click image for larger version.
    Clearance issue solved. Bleeder valve still fouls. But easily resolved.
    Also think I'm going to do the unthinkable - heat wrap my exhaust in black. Pretty vs. practicality.
    They run so close to the dizzy, starter, slave and oil filter. Will also keep engine bay temps down.
  4. #234
    Senior Member 4doors's Avatar
    Jul 2010
    Andy
    goldy
    Good to see the updates coming through buddy. Inspires me to actually work on my build!
  5. #235
    Eddie
    Ceramic coat the extractors. Heat wrap is crap to work with and tends to explode if it gets wet.
    Sent from my iPhone using Tapatalk
  6. #236
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    I even had problems with a ceramic coated header. You may have to fabricate heat shields for the dizzy, oil filter, and possibly the engine mount. My slave cyl on the other side, but that could also heat soak. Dave W
  7. #237
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Header wrap works well for me in keeping bay temps down, still need a heat shield for starter and distributor though. Fine on the road, just with long periods of throttle on track they tend to melt.
    Make sure you have long rubber gloves though, gets itchy fast otherwise.
  8. #238
    Veteran Konakid's Avatar
    Henry
    Eastern
    Defineitely ceramic coat, amazing the difference. then heat wrap as well even.
  9. #239
    Aug 2012
    Jarrad
    east
    Finishing touches on this side of the exhaust and clutch. You can see I've finally mounted it properly (minus the spring) and got a short bleeder valve for the hilux slave.
    Also ended up wrapping my headers. Read a few different views on them but at this point and how often I'll be driving the car very hard I think they'll be okay. I left the bottom part unwrapped and the rest of the exhaust won't have it either so I guess some heat will still be able to escape. Plus when it gets tuned, it should be tuned when at temperature and I'm guessing some of the excess heat generated will hopefully be used in combustion *shrugs* haha
    Also fitted the drive belt, had to go longer to allow the alternator to clear underneath the carb and water lines. It's all very tight and I was worried about the heat on the intake side too. But as pointed out to me, silicon is a great insulator (oven mits, cake tins) so shouldn't transfer much heat.
    It's so close.
  10. #240
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Heat wrap looks good. If I do it again I will consider black actually. Much more subtle, would be perfect for a street car where you don't want to draw too much attention
    Current Cars:
  1. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 12th December 2010, 11:17 AM
  2. Jarrad's RA65
    Last Post: 16th October 2009, 12:09 AM
  3. My Project AE86
    By 4A-GE Power in forum AE86 Owners Forums
    Last Post: 2nd October 2008, 08:13 AM
  4. ADM resto
    By Judge Fudge in forum Cars or Parts Wanted
    Last Post: 14th August 2008, 07:21 PM
  5. Teddy's JDM Ke70 ground up-every bolt spec. Resto!
    By Teddy in forum KE70 / AE71 Owners Forums
    Last Post: 26th June 2008, 07:20 PM
