Results 1 to 4 of 4
Thread: Carbon canister 4age ke70
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Carbon canister 4age ke70
    Hey so I've tried some googling with no luck.
    I need to put my charcoal canister back in my ke70. Currently running a 4agte. I understand what there for although I have no idea how they work!
    2 questions..
    1, can I go to a wrecker and pull out any canister, from any car and hook it up to my setup ? Or does it have to be 4age specific?
    2, vacume to the canister, does it have to go through a vsv, or can I run a direct constant vacuum source ? Also I Don't have any wiring for a vsv
    Im running a custom plenum and have a spare vac nipple so it will work out well if I can.
    Don't be hating on my stupidness!!
    thanks in advance..
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    Any carbon canister will do but some have quite a few fittings on them, I look for ones with just the line from the tank breather system & a vacuum source line, you will need to run ported vacuum in that it comes from a fitting around the throttle butterfly & so will not have any vacuum at idle & will only be there as the throttle is opening, some have a delay valve fitted inline too so it doesn't pull air through the carbon canister as soon as the throttle is opened ..
    May 2010
    Adam
    St George
    Cool... Do u reckon I can just put a restrictor on the vac line?
    Jul 2010
    Rob
    Do you mean put a restrictor in line & have it connected to your custom plenum & so it pulls vacuum all the time ... Not ideal if that's the way you were thinking of plumbing it ...
  1. BT 20V 4AGE + charcoal canister
    By 70XIN in forum Technical - Questions
    Last Post: 30th September 2010, 07:01 AM
  2. carbon canister
    By mini bus in forum Technical - Questions
    Last Post: 18th January 2009, 10:09 PM
  3. carbon canister
    By 86adz in forum Technical - Questions
    Last Post: 1st August 2008, 09:54 AM
