Results 1 to 10 of 19
Thread: 86 Yota
    Dec 2013
    Max
    Hawaii
    Honolulu
    United States
    Smile 86 Yota
    Aloha guys er, mates.
    Just joined this forum to increase the odds of me finding parts to fix my little hachi. I always saw search results point back here but never got around to getting an account until now; that's what happens when you're on holiday vacation. As with first posts, here's an introduction to my project car. I bought this back in 2003 and had her ever since. Now, I'm in the midst of getting her prepared for autocrossing. If you have any tips on techniques and setup for road race, I'd love to chat.
    Specifications
    Engine
    4AGZE (90.1 - 90.10 AE92 MAP/DLI P/N 89661-12611)
    FMIC with custom ducting/thermal wrapped
    Walbro 255lph Fuel Pump
    Tomei FPR
    HKS Grex Oil Filter Relocation
    HKS Sport Catback Exhaust
    Magnaflow Hi Flow Catalytic Converter
    TRD 4-1 Exhaust Header
    Cusco Oil Catch
    Koyo Aluminum Radiator [Single Electric Fan]
    Mota Aluminum Vacuum Tank (A70269)
    Odyssey PC680 Dry Cell Battery
    Chassis
    Cusco Front OS-Type STB
    Cusco Rear OS-Type STB
    AMT Rear Tri-Bar
    UEO Style Fender Braces
    NRG Sear Harness/'B'-Pillar Brace Bar
    Aerodyne 'C'-Pillar Brace Bar
    Suspension/Steering
    Trust Greddy Type 'S' Coilovers (8kg/mm[448lbf/in] | 6kg/mm[336lbf/in])
    Tanabe Front/Rear Sway Bars (25.4mm | 20mm)
    TechnoToyTuning RCAs
    TechnoToyTuning Tension Rods
    NRG Tension Rod Brace Bar
    BattleVersion Traction Brackets
    BattleVersion Panhard Bar
    BatleVersion Rear 4-Links
    Manual Steering Rack/Power Steering Knuckles
    TechnoToyTunning Outer Tie Rods
    Brakes/Wheels/Tires
    SS Braided Brakelines
    (F) Brembo Slotted/Drilled Rotors
    (R) Bradi Slotted/Drilled Rotors
    Hawk HPS Ferro-Carbon Brakepads
    SSR Formula Mesh 15x7" Wheels (12/0mm)
    Falken Ziex ZE912 (195/50R15)
    Body/Aero
    JDM Kouki Front/Rear Bumpers
    JDM Zenki Front Lip Spoiler
    JDM Redline Kouki Taillights
    JDM Kouki Eyelids/Corner Lights
    TRD-Style FRP Hatch
    C4AG CF Visors
    CF Vented Hood
    CF Headlight Covers
    CBY Sideskirts
    CBY Carbon Replica Fender Flares
    Rear Bumper fins
    Interior
    Nardi Deep Corn 330mm Steering Wheel
    Corbeau TRS Seats
    Sabelt 4-Point Harnesses
    Autometer 10k Tachometer
    Autometer Boost/Volt/Oil.P/Water.T Gauges
    Viper 5901 Alarm System
    Webasto Hollandia 300 Deluxe Sunroof
    Photographic Evidence
    Video Daily Double
    Veteran drift kid's Avatar
    Glossodia
    Looks nice man, clean as a whistle
    Very clean and nice
    Nov 2009
    Flaxton
    Sweet car. How big are thoughs flares? Where you'd get them from?
    Dec 2013
    Max
    Hawaii
    Honolulu
    United States
    Matt, the flares are CBY carbon replicas that I purchased from someone who had a shop fabricate it for him, fairly certain it was Battle Garage. He went a different route in regard to flares. The flares the front are 50mm wider, rear is 65mm. I just ordered wider wheels to fit the flares better.
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Looks great dude. Very Clean.
    So what parts you need to fix ur 86
    Dec 2013
    Max
    Hawaii
    Honolulu
    United States
    Well, to be honest I am not completely sure what parts I need to fix it. There seems to be a lack of boost and I've already replaced the map sensor and fuel pump. I also verified operation of the electro-mag s/c clutch. It all seems in order so I'm thinking it's the ECU which somehow went defunct. Here's what the car sounds like at startup and at 5k blips. Could use some advice.
    Mar 2013
    Mirko
    Hmmm sounds a bit rough on idle as well. OK not sure but would check the following before doing ecu
    1. Spark Plugs
    2. Airflow Sensor see if its in good nick
    Not sure on ECU might be simpler if u swap out a aftermarket one rather then standard once gives more tuning options
    Nov 2009
    Flaxton
    Ohk, thanks for that. Yeah better fitting wheels well make it look a lot better. What are you going to put on?
    Dec 2013
    Max
    Hawaii
    Honolulu
    United States
    I've actually replaced both those things quite recently. I used NGK Iridium spark plugs and replaced the MAP sensor with one from a 2JZGTE (Mk 4 Supra). Didn't seem to do the job though. I'm planning on getting an aftermarket ECU, probably a Megasquirt since the shop I frequent recommend using that with my setup. They said either that or Haltech but they speak more highly of Megasquirt.
  1. Rumours: Australia to get TRD Kit option for the Toyota 86 GTS 86
    Last Post: 30th December 2013, 07:13 AM
  2. 16valve 4age, 86 sideskirts, 86 adjustable panhard rod :)
    By timpy in forum Car Parts For Sale
    Last Post: 5th October 2010, 08:23 PM
  3. Replies: 29
    Last Post: 16th July 2007, 01:22 PM
  4. 32/36 weber, 86 doors, 86 hatch
    By Craig_AE86 in forum Car Parts For Sale
    Last Post: 17th May 2007, 01:56 PM
Tags for this Thread
