Im in the process of converting from carbs to efi with itb's. I have a vipec v88 ecu and the plan is to hopefully have a really good cold start idle operating in closed loop. Coming off my t3 manifold i have 4mm pneumatic push on fittings which i intent on running equal length hoses to a small manifold which has a 6 wire 1jz stepper type iacv mounted onto it. Also coming off the vacuum manifold will be my vacuum source for my booster. I would like this setup to only be used for cold starts and be closed when the engine is warm idling via the bleed screws on the throttles. I am not going to be using a map sensor for tuning. This setup seems to work in my head but any feedback, opinions or criticism would be greatly appreciated. Cheers, Trent
