Results 1 to 8 of 8
Thread: S13 into Ae86 Coilover Setup
    Senior Member Mad RS's Avatar
    Queensland
    Wynnum
    Default S13 into Ae86 Coilover Setup
    Hey Guys,
    I have tried every search that I could think of but I don't seem to be able to find what I am looking for.
    I've just picked up a Ae86 that is running a S13 front brake and coilover conversion. I am looking to reduce the severity of the front camber by moving the bottom of the wheel in and not the top of the wheel out.
    Is there an adjustable LCA that will bring the length back to close to stock Ae86 length??
    Would this cause an issue with the current setup??
    If you could point me to any good threads detailing further mods that would be a great help. I will keep looking though.
    Veteran AJPS's Avatar
    Lonsdale
    the issue with the front suspension is that it is from a nissan silvia
    you could get someone capable to cut and shut your lca to bring it in
    Veteran drift kid's Avatar
    Glossodia
    I can do full LCA mods to whatever spec you need
    Mt Macedon
    It depends a lot on what LCAs you're running at the moment. From memory S13 arms are about 10mm shorter than MX62, both of which work with slight modification.
    Cutting and shutting your arms or changing to adjustable rose joints at the inner end are both entirely possible solutions too.
    Queensland
    Wynnum
    Thanks for the help guys
    Run what ya brung...............and make damn sure ya brung enough!!!!
    Junior Member captainslow's Avatar
    Jan 2011
    Danuel
    Devonport
    If your current setup is running s13 lca's you could swap them for r31 lca's, they're shorter and should but straight up
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    This ^ from my personal experience I was running a s13 lca and swapped it out for a r31 lca. Got rid of the excessive camber issue with sill plenty that can be dialed in or out with camber tops
    Mar 2011
    Ali
    Tie rod end / rack end length is going to come into play, it will be pigeon toed.
    How much adjustment is there?
  1. Replies: 2
    Last Post: 21st June 2013, 02:28 PM
  2. FS: AE86 Coilover setup + ADM Brakes
    By Tally in forum Car Parts For Sale
    Last Post: 18th June 2013, 02:37 PM
  3. Replies: 2
    Last Post: 9th December 2012, 12:21 PM
  4. s13 Coilover front set up!!!!!!! s13 crossmember + rack
    By skin in forum Car Parts For Sale
    Last Post: 27th September 2010, 09:16 PM
  5. FS: Coilover setup for AE86
    By sideeways in forum Car Parts For Sale
    Last Post: 26th January 2010, 04:10 PM
