Results 1 to 4 of 4
Thread: Turn signal and hazard lights wiring plug
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Default Turn signal and hazard lights wiring plug
    Re wiring my 86 using a aftermarket harness so need to work out what wire does what. Now I have the wiring guide but some wires don't match up ie the red ones for example so need to know the wiring guide for the following Click image for larger version.
    If anyone knows what colours are what think I know a few but not sure so any help would be great
    Mar 2013
    Mirko
    Bump anyone? Anyone doing a new custom wiring harness install would love to chat to someone who has for some advice paying beer
    Site Supporter Javal's Avatar
    Josho
    Charity post.
    Can you read a wiring diagram?
    Can you operate a multimeter?
    If so you can save yourself. Fab'ing a wiring loom is a huge task. It will at times best you.
    Here's a link to a TE71 wiring diagram.
    This is my go-to diagram for all xE7x and early to mid 80's Toyota wiring. Toyota are good in that the colours are usually the same across the models and they're usually colour grouped together for various systems.
    For example:
    Reds are usually headlight wiring
    Greens are other lighting (park, tail, indicator)
    Blues are washer motor etc
    Whites are B+ constant power
    Black with red usually IGN ON power
    Black with yellow usually IGN ON power
    Black with white STA power
    White with black trace is ground.
    Holding true to this, your Red wire with Yellow trace (stripe) is your High beam ground path (refer circuit diagram - headlights have switched power and switched grounds to do hi / lo / off)
    Anyway. Have fun.
    Mar 2013
    Mirko
    Yes and yes but only one giving me issue is the lights indicator rest have worked it out.
    Thanks for that ill use that and let you know
  1. Head lights won't turn off!!??
    By adds in forum Technical - Questions
    Last Post: 28th December 2012, 09:10 PM
  2. Dash lights turn off.
    By Ade_Mc in forum Technical - Questions
    Last Post: 3rd November 2010, 09:41 PM
  3. Identify that 20V Wiring Plug
    By tuned86 in forum Technical - Questions
    Last Post: 5th March 2010, 12:55 AM
  4. thermo fan question, where is the signal plug
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 12th May 2009, 11:47 PM
  5. tps wiring plug
    By roger roger in forum Technical - Questions
    Last Post: 14th June 2008, 11:18 AM
