Results 1 to 10 of 11
Thread: Recommendation on filling holes
    Junior Member CrewChief's Avatar
    May 2014
    Dustin
    Idaho
    Mountain Home AFB
    United States
    Default Recommendation on filling holes
    My hatch has some holes where rivets used to bolt the spoiler used to be. The guy i bought the car from removed the spoiler and patched up the holes with duct tape. I want a more permanent fix. Any recommendations?
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Weld them up and then paint it again. Thats the best option out there
    Led wiping is an old school method that works really well, but you need an oxy.
    But if they are small spot welding can work pretty well or plug welding them with a mig.
    Aug 2013
    Graham
    Refit spoiler?
    May 2014
    Dustin
    Idaho
    Mountain Home AFB
    United States
    Cant afford a new spoiler at the moment or else i would..
    Mar 2013
    Mirko
    Get some rubber grommets to fill and will seal it as well
    Veteran drift kid's Avatar
    Glossodia
    I'm assuming that they are quite small holes so rubber grommets may not work, at the end of the day as matt said led wiping it is one of the best options but it is also a dying art (sadly) and it is not common practice anymore, the most practical method would be to use the mig on a low enough setting so as not to put heaps of heat into the panel but high enough setting to make it weld properly, then linish the welds back flat, maybe a skim of filler to make it smooth and then off to paint
    Aug 2010
    Geoff
    mt dandenong
    You can buy little threaded studs with rubber o rings to plug up holes temporarily if you intend on refitting a wing at some stage.
    Normally used to plug holes after de-badging
    Joel
    sticks
    I'm not a fan of lead (not led ffs!) wiping. To me it is just like bog carving except the finished surface is softer. Also while the peak temperature is lower than welding you still have to be very careful because it is the total heat put into a panel that does the damage.
    Mig all the way.
    Eddie
    You could also try metal apoxy to fill it. It'll stay pliable enough at the beginning to get a nice finish and should be able to fill a rivet hole nicely. Also added benefit of no heat.
  1. T50 gearbox filling question
    By ke_70_blue in forum Technical - Questions
    Last Post: 4th December 2012, 08:42 AM
  2. Gauge recommendation!
    By Sherlock in forum Technical - Questions
    Last Post: 30th June 2010, 09:47 PM
  3. coolant recommendation
    By Group A in forum Technical - Questions
    Last Post: 29th June 2010, 07:32 PM
  4. mmm CREAM FILLING!
    By todd in forum Youtube Chan
    Last Post: 18th December 2009, 11:45 AM
  5. gbox oil filling from shifter
    By AE86.cn in forum Technical - Questions
    Last Post: 21st August 2008, 12:09 PM
