Results 1 to 10 of 17
Thread: Take a look !!
    Junior Member bytrdjapan's Avatar
    Aug 2013
    ioannis
    AU
    AU
    AU
    Default Take a look !!
    1. T3 Outer Tie Rod/Knuckle Kit
    2. T3 tension Rods
    3. GR4 fabrication control arms
    4. ShockWorks coilovers
    5. Stock sway bar.
    Have a problem as you see in the PIC's any similar occasion please ?
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Standard lower control arms? if so you might need to drill new holes
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I would counter-sink the bolt holes in the tension rods and use countersunk head cap screws.
    West
    You can shave a fair amount off those well oversized ttt steering arms before you would weaken them I think.
    Senior Member lappy's Avatar
    Brenton
    Eaton
    Had the same problem and worked out you can use it all if you run no camber and that's about it, I just sold them and went ps knuckles after counter sinking the bolts aswell
    Aug 2013
    ioannis
    AU
    AU
    AU
    Hi !!
    You mean counter-sinking the bolts of the Tension Bars ?
    I was thinking to machine the ttt knuckles close to stock ones to achieve more clearance .
    What do you think ?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Just put a grinder to the arms, hopefully you can loose some of that excessive dead weight.
    Aug 2013
    ioannis
    AU
    AU
    AU
    You mean Grinder to the knuckles right ?
    Aug 2013
    ioannis
    AU
    AU
    AU
    Hi guys !!!
    After two days of speaking with machinery guys the entire T3 Knuckle Kit its a s@%ty piece of sheet-metal,
    that's explain the thickness.
    Its risky to be machined ,all be afraid the crack afterwards.
    Hardness measurements:
    Stock: 360 Brinell
    TTT: 180 Brinell
    Veteran AJPS's Avatar
    Lonsdale
    Yep. Get rid of them. Quite a crude piece of equipment. Plenty of better options.
