T series zenki disc axles?
i have a few t series diff parts including the out side housing that the c& p bolt into
also have 3 rwd 4age alternator brackets 150 each plus post
t series axles early types etc 150 the pair
1 f series axle 100
plus numerous 4age blocks and bigport heads
no just normal drum t series axles most likely ra23/40/t18 etc
i know its not advertised but would you happen to have a series one center lying about?
not a complete center outer housing with bits and peices
fair enough, worth a try
Glenn - Could you measure those axles for me? I need some for my T18 T Series Housing.
Thanks
Dan
axles are 665mm long to axle face where wheel studs are
Thanks Glenn - They were from an RA40? They should fit T series from a T18 as the diffs are the same width - I'll take them!
Will send you an email
Dan
Are you selling the backing plates by any chance
My AE86 4AGZE to 3SGTE thread
Check out my sale threads for 4age and ae86 parts
http://www.ae86drivingclub.com.au/fo...nd-going-Turbo
http://www.ae86drivingclub.com.au/fo...ything-must-go
Sponsors
Platinum Automotive Smash Repairs - Padstow
