i will replace the inner section of the rail, skirt is easily repairable rad support will be replaced in sections (rhf headlight panel and top lock panel). the lh headlight panel isnt damaged and lower tie bar isnt damaged.
AE86 THE BEST
Yeah i was hoping you'd say that
Damn shame![]()
Former Cars: 1992 300zxTT ***SOLD***----------------1984 Daily 20v AE86 ***PARTED OUT*** =(
Current Cars:
Project Ugly Duckling - 1984 AE86 SR drift car ------------------Daily JDM Trueno GT-APEX hatch![]()
Rhf headlight panel removed
smallport manifold with front all ground up ready to weld
there is a small hole in the pcv hose into the maifold that always breathes crankcase vent
mad a jig with a pece of angle and vice grips and a pointer to scribe a cut mark straight around the mani
the little mount for the accelerator cable (made from a volvo reinforcing bracket)
the jig i made to mount the accelerator cable mount in the correct place
before i started cutting
started ecu wiring
made an alternator bracket with the base of the ae93 alt mount and a piece of flat
rwd cooling setup
pic of the inside of a runner in the manifold
AE86 THE BEST
got some good work done today, hooked up the chassis straightener and pulled the rail straight, pulled the floor damage out and unspotted the inner chassis rail section. had an old jap halfcut i got about 15 years ago which will be the donor for the rail, rhf headlight panel and top lock panel. will put the new rail on tomorrow and have a play at lining things up!
AE86 THE BEST
Thanks for keeping up the photostream Eddie.
Not being a panel beater or anything this process is super interesting for me
Current Cars:
Yeah great work man
