nice man should go for a run 2g4
Yes, chop them up!
No, keep them clean!
Might get to take this for a spin around the block tomorrow ... im gonna run it on a pressurized fuel canister we have thats made for injector cleaning ... but instead of putting injector cleaner in it im just gonna do straight fuel. all i gotta do it connect it straight into my fuel rail and then sit it in the engine bay somewhere safe and go for a drive.
ok so this is what i got happening today ... i hooked up the canister of fuel and it wanted to start but it just couldn't keep running ... it would start to fire but it would die after so i grabbed the aero start and with a nice spray of that she fired up and kept going ... but then it started to sound how it dose in the video ... it sounded like what my current daily dose when its low on water ... the auto choke thingy at the throttle body plays up on it and it revs like that when its idling ... so im gonna take that off and clean it out and hopefully that will stop it from having the funny idle ... but i also noticed that my tacho wasnt working ... im not sure if its connected atm so ill have to check that out ... who knows what the wire colour it is where it connects to the dash cluster ...
one other this is i didn't have any throttle response ...the butterfly was opening and closing but no change in the revs ...
and then disaster ... i had to kill the motor quickly ...
she started to bleed.
not good![]()
mid way threw the test the air hose that keeps the little canister pressurized blew out thats when i had to stop recording ... but it still ran for a bit after that untill i killed it cuz i saw the oil ...
the exhaust note from this sounds nice to ... its not real loud but it had a nice tone to it and it should sound sweet up passed 6k rpm.
ull have to get it to sound like mine
Front main seal time.
yep front main ... im gonna price one up tomorrow as i didnt have time today ... and my 4A-GE manual shows me exactly what i need to do ... but its rather simple anyway ... its the same seal design as the one i just put into my gearbox.
picked up a new front main seal today ... $14.50 from toyota.
ok so i got a charcoal canister from SteroidChickens the other day along with some sideskirts but im not real sure on if i like the skirts or not obviously ill be investing in a front lip shortly after its running and rego'd but i got these, i really wanted ones like this...
They are standard ones. that being said i will swap these for some standard ones
but untill then i might run with these on. let me know your thoughts
Paid a deposit on a T series yesterday, comes with a TRD 2 way LSD , drive shaft, and all the other stuff to bolt in except for calipers and hand brake cables.
