Results 1 to 10 of 18
Thread: Ae86 mpg
    Default Ae86 mpg
    Still trying to get to the bottom of another issue without putting the car out of action as I need it.
    What sort of fuel usage figures do you guys get,
    On a good hard run I got 300km for 30ltrs at the pump, so thats a Litre of fuel for every 10km
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    i usually get around 400 to a tank depending on how i drive. just a std 16v with a jap ecu
    FTP.
    Jonathan
    So that is 10 litres per 100km.
    Not too bad for going hard.
    You could get it down to 6L/100km if cruising on the highway using very little throttle.
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    I get about 350 - 370km to a full tank. depending on how heavy my right foot is during that period. I've got a smallport 16v with a standard adm ecu.
    yeh 10l/100k is good.. since many new cars get around that.
    性交を愛する
    I got 30$ for about 350kms from the nebo/glorious run.
    marvis.
    Veteran Wally's Avatar
    ~400-425 (45L) when I used to drive to work.
    4AGE 16V
    Veteran Nikkojoe's Avatar
    Tom
    With A/C I get 10L/100km, without I get 7L/100km.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i used to get 6L per hundered in a 4ae driven like a granny. 8L per hundered with a 15psi 4agze flogged everywhere
    Mason
    Salisbury East
    A good healthy running 4age should get around 7.2 to 7.8 litres per 100 k's city driving
    with a bit of thrashing too and around 6.6 to 7 litres per 100 k's highway cruising.
