Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 10 of 102
Thread: Genuine Part numbers, How to get new parts for your 86
    Default Genuine Part numbers, How to get new parts for your 86
    This is actualy a fairly big topic, and I will add more stuff and advice on how to deal with Spare Parts guys at your local (un)friendly Toyota dealership. For now, I will list common parts you may want to buy which are probably avaliable, and less common parts for GT spec. Others can add what price they paid and who they talked to, so others can know what to expect. But if you are armed with a ID plate, a Toyota parts man should be able to get almost anything. Many parts are different between early model and late model, and the date change is 8505 (May 1985). But many other mechanical parts have been changed at different dates.
    Price:
    I have put up the suggested list price, which maybe out of date by a few months or years.
    JDM parts, most not in Europe or America:
    ####-#### Apex/Levin/Trueno rear stickers. Lots of colors, combos etc...
    81210-12030 fog lamp, RH late model levin apex
    81220-12020 fog lamp, LH late model levin apex
    81550-1A230 RH tail light, early levin 3D (lotus)
    81550-1A231 RH tail light, late levin 3D (whiteline)
    81611-12290 RH park light, late levin
    81550-1A291 RH tail light, late trueno 3D (redline)
    81560-1A291 LH tail light, late trueno 3D (redline)
    75803-12070 centre moulding, late trueno 3D (redline)
    81270-12320 lamp assy, licence plate. all JDM except late 2D
    ... I can't be bothered posting up all body parts right now.
    General AE86 parts for GT, GTV, Apex, GT-S:
    04111-16024 full engine gasket kit 4A-GEU
    04112-16024 head gasket kit 4A-GEU
    90105-10076 flywheel bolts $3.50 +GST
    90311-70004 rear main seal
    90311-70007 rear main seal AE92 $36.05 +GST
    90311-32020 front seal $10.71 +GST
    12511-16011 Cast iron alternator bracket $127.11 +GST
    16381-16010 Top adjuster alternator bracket $13.08 +GST
    16371-16021 Waterpump pulley $54.53
    5PK835 or 5PK840 fan belt (generic belt number)
    78180-12410 accelerator cable (RHD 4A-GE)
    16331-16020 outlet, water (front of head, fitting for rad hose)
    16323-16020 thermostate housing 4A-GE $63.78 +GST
    11181-16030 water block at back of head 4A-GE $61.50 +GST
    16110-19155 waterpump complete 4A-GE $80.40 +GST
    16571-16010 top radiator hose 4A-GE $22.38 +GST
    16572-16010 bottom radiator hose 4A-GE $22.38 +GST
    16401-63010 radiator cap
    16405-16010 coolant overflow bottle
    16611-16010 bracket for overflow bottle (same bracket is on AW11 and Coaster Bus)
    90915-10004 oil filter (Denso Japan)
    90915-YZZE2 oil filter (Denso Thailand)
    Z386 generic oil filter from Ryco
    85331-12340 or -12350 windshield washer bottle (RHD, 4A-GE)
    31470-12050 clutch slave cyl
    47201-12340 brake master cylinder
    04493-12120 brake master cylinder kit
    04479-14060 front brake seal kit (all)
    14479-12110 rear brake seal kit (disk)
    46420-12300 RH handbrake cable (disk)
    46430-12200 LH handbrake cable (disk)
    04421-14010 rear axle bearing kit (early and late disk)
    90311-52059 rear axle seals (disk brake) $13.90 + GST
    42311-12100 rear axles (disk brake, early)
    42311-12101 rear axles (disk brake, late)
    90942-02047 rear axle studs
    41201-29207 final gear kit, N=43:10
    90116-08235 studs for diff housing, short
    90116-08236 stud for diff, long
    31321-12030 clutch and brake pedal pads
    55478-12040-01 clock suround, black $12.70 + GST
    58951-12091, or -12101 center consol lid
    69260-14020-01 or -14030-01 or -12090-01 window winders, black (same as AW11)
    81241-20060 interia light lens (same as HiLux duel cab)
    45611-12917 RH steering knuckle (power steering or GTV)
    45612-12917 LH steering knuckle (power steering or GTV)
    45522-10021 rack bush, manual steer $36.37 +GST
    23206-16170 in-tank fuel pump bracket
    ## see below ## in-tank fuel pump (same as most other Toyotas of that era)
    23091-12020 short fuel hose between 8mm line and tank
    77205-12120 hard fuel line 8mm (EFI 4A-GE) $76.45
    23300-19025 fuel filter with bracket (EFI) $95.50 + GST
    90923-01278 flex fuel hose in engine bay, banjo ends
    90401-12097 banjo bolt for fuel filter
    75531-12270 top outer windscrean moulding, alloy $70.95
    door hinge ~$45 each
    76081-12010 front lip (early levin, includes bolts) ~$300
    33548-14010 plastic bush on gear lever
    31126-20070 rubber boot for clutch fork $22.75 + GST
    Interia COLOUR
    For a trim part, the last number refers to the colour. -01 means black. For early JDM models, most interia parts were either maroon or blue. For late model cars most parts are black.
    -01 black
    -02 maroon
    -03 gray
    -04 blue
    -05 beige
    -06 brown
    -08 ivory
    -11 new black
    -13 gray
    -14 blue
    -16 brown
    -59 dark blue
    Random AE86 Parts
    Item | QTY | Price | Dealer | Part number
    Lower Radiator Hose 1 $21.45 Toyota Parts Lower 16572-16010
    Engine Mount Nut 2 4.10 Toyota Parts 94115-41200
    Engine Mount Bolt/Washer 1 2 4.60 Toyota Parts 90201-12208
    Engine Mount Bolt/Washer 2 2 4.10 Toyota Parts 94511-01200
    Engine Support Stud-Bolt 1 7.50 Toyota Parts 91621-61040
    Exhaust Gasket 1 27.70 Toyota Parts 17173-16010 (17173-AE801)
    Upper Radiator Hoses 1 $21.45 Toyota Parts Upper 16571-16010
    Manual Steering: 45209-32010 or 45209-10020
    Power Steering: 45209-12040
    Rocket Cover Nuts (intake) 4 16.15 Toyota Parts 90176-06012
    Rocket Cover Washer 8 12.70 Toyota Parts 90210-06013
    Clip Holder for mounts (brakes) 8 21.65 Toyota Parts 96991-10080
    Ring for brake line 8 28.50 Toyota Parts 96160-01200
    Rear Damper Bush 2 24.80 Toyota Parts 90385-16001
    Cushion, UPP Rear Shock Absorber 2 7.70 Toyota Parts 90948-01003
    Cushion, LWR Rear Shock Absorber 2 11.50 Toyota Parts 90948-01018
    Cushion Washer for Shock Absorber (Top & Bottom) 1 2.60 Toyota Parts 90948-02002
    Park Brake Cable R 1 83.60 Toyota Parts 46430-12200
    Park Brake Cable L 1 83.60 Toyota Parts 46420-12300
    Pin w/hole for Park Brake Cable 2 6.10 Toyota Parts 90240-08040
    Rear Disc Brake UPR bolt $12.80 Toyota Spares 90119-08431
    Rear Disc Brake LWR bolt $3.45 Toyota Spares 90109-08098
    Retainer Washer for Shock Absorber (middle) 1 $3.00 Toyota Parts 90948-02007
    Cotter Pin for Park Brake Cable 2 $2.40 Toyota Parts 95381-02020
    Washer Caliper-Bracket 4 $5.55 Toyota Parts 94531-01000
    Toyota Steering Mount Bushing 2 Toyota Parts 45516-12040 ("D" shaped mount) and without p/s 45517-12080
    Flywheel Bolts (AE82) 8 Toyota Parts 90105-10076
    Metal Brake Tube L (need JDM chassis) 1 17.40 Toyoa Parts 47324-12150
    Metal Brake Tube R (need JDM chassis) 1 19.70 Toyota Parts 47325-12150
    Propeller Shaft Insulator 1 33.50 Toyota Parts 37239-12040
    Clutch Master Cyclinder 31410-20282
    The bushes are mostly the same for any AE86 and KE70. Your local dealer can look them up easily. But not sure how easy they are to get. I got the numbers for you anyway. Personaly I have used polyurathane, Nolathane or SuperPro. Depends what feel your after. Note that you can get TRD bushes also, which are also black rubber. Maybe they are stiffer (not as stiff as polyurathane), or maybe they just cost more?
    Front bushes:
    48654-12010 lower control arm
    48674-19058 or -12040 radius rod kit
    48603-12010 RH strut top GT (more caster)
    48609-12100 LH strut top GT
    48603-12040 RH strut top SR (less caster)
    48609-12130 LH strut top SR
    48815-14140 D bushes
    48817-20020 link bushes
    Rear bushes:
    48706-14010, 90385-20001, 90386-20001 panhard rod
    4-link bushes, not a part, need to get whole arms.
    48815-22100 D-bushes
    90385-11021, and 48817-12010 link bushes
    "Redline" tail lights:
    81551-1A291 RH lens only
    81561-1A291 LH lens only
    81550-1A291 RH assembly with lens, globes, seals and harness
    81560-1A291 LH assembly with lens, globes, seals and harness
    90179-05095 x4 bolts/clips
    Early Levin:
    52119-12090 front bumper dark gray
    52119-12091 front bumper black
    52159-12060 rear bumper dark gray
    52159-12061 rear bumper black
    Late Levin:
    52119-12152 front bumper black
    52119-12142 front bumper black
    52159-12092 rear bumper black
    52159-12062 rear bumper black
    Kouki Windscreen Moldings
    Part No..............Est Cost: Ex Japan 4-5 WEEKS
    75531-12271......$80.00 (Top molding)
    75535-12130......$227.00 (Lower Molding)
    75533-12200......$48.00 (RHS molding)
    75534-12130......$48.00 (LHS molding)
    62383-12010......$86.00 (Weatherstrips) This cost is for both LHS and RHS. (Part # superceeds 62384-12010)
    Bezel, auto clock hole:
    55478-12040-01 black, in stock (even though not a AUD item)
    55478-12040-02 maroon
    55478-12040-12 maroon
    55478-12040-04 blue
    AE86 Fuel Pump
    23220-16070 AE86 fuel pump (EFI)
    23220-16080
    23220-16082
    23220-16083
    23220-19015
    23220-16190
    23249-43080
    23220-16084
    All these numbers are for AE86 in-tank fuel pump. (Pump only, no bracket) Either Denso or Aisan, and seam to have been updated every year. But use the same bracket.
    The exact same pump is also for:
    RT142 Corona (22R-E)
    AE82 Corola (4A-GE)
    AW11 MR2
    MA61 Supra
    RA65 Celica
    ST16# Celica (3S-GE)
    SV11 Camry
    SV21 Camry
    GX71/MX7# Cressida
    MS123 Crown
    YR20/22 Tarago
    FJ62 Landcriuser (3FE)
    4-Runner (with 22RE or 3VZE)
    23249-43080 This pump is listed for AE86, but is also listed for:
    AW11 MR2 (4A-GZE)
    ST165 Celica (3S-GTE)
    MA70 Celica (7M-GTE)
    Ae86 Alternators
    27060-16010
    27060-16050
    27060-16090
    27060-16011
    27060-16012
    27060-16091
    Any one of these numbers will be a alternator for a RWD 4A-GEU. I know a dirrect swap is the alternator from a 20 valve, except the electrical plug is probably different. Oval instead of round.
    AE111 4A-GE
    90913-02092 qty8 valve stem seals, exhaust
    90913-02093 qty12 valve stem seals, intake
    11122-16040 qty12 intake valve guides, std
    11126-16020 qty8 exhaust valve guides, std
    t-50 REBUILD KIT
    33548-14010 plastic bush on gear lever *this part is no longer available i will go to another toyota to check it again. as i was intending to replace these essential shifting parts.
    33556-14010 plastic bush at seat of gear stick; is still available (this gets worn out to nothing over time)
    33556-14020 is the seal beneath the plastic bush seat
    just to add for a JDM 4age rwd water pump assembly part number is 1610019095 price is 185.32 + gst so say 200 ish
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Quote Originally Posted by *urban_ninja* View Post
    is this for the whole pump setup or what thermostat aswell housing and all because that is sorta cheap isn't it
    the dyno pull to 300rwkw
    no thermostat or water by pass pip just the pump and backing plate section with the gasket in it all other parts are seperat i got a pump thermostat water by pass pipe and head bolts for like $300 i think or less.
    Colin
    Gold Coast
    great list. wondering if anyone knows the Toyota part number for kouki trueno smokey eyelids to go onto the trueno pop up headlights? any help with this would be huge!
    Member Fooly Cooly's Avatar
    Ed
    Gold Coast
    Default ae86 a/c compressor
    does any one know the a/c compressor numbers of the compressor and front hub (Denso numbers not toyota numbers) particularly the front hub numbers on the compressor! i know it has a 10p15c body type Thanks to craig at just jdm! but need to match a clutch to it! Thanks!
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    does anyone know the part numbe for the accelerator cable?
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    It is listed above
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Veteran Nikkojoe's Avatar
    Tom
    Quote Originally Posted by Fooly Cooly View Post
    I have one in my garage. Zenki and kouki are slightly different (kouki has high pressure switch on compressor).
    Zenki 4age compressor is same as 4ac, just has multi-rib pulley. Will get the denso number off it for you.
    Parcel Shelf ?
  1. Genuine Parts, Part numbers
    By Jonny Rochester in forum Technical - Articles
    Last Post: 11th September 2008, 12:42 PM
