Results 1 to 10 of 11
Thread: Omori Oil Temp Guage!
    Senior Member Ksevn-T's Avatar
    Default Omori Oil Temp Guage!
    hey guys, have for sale here a mechanical omori oil temp guage. Looking for 60ono. Very minor cosmetic scratches, nothing a can of paint couldnt fix. Numbers illuminate green whils the needle, red. Will post at buyers expense. Locared SE suburbs Melb.
    Alex
    数独のガレージ "Sudoku Garage" <3<3<3
    Kevin
    Queensland
    North Lakes
    i will give u 65 including post to 4053 in brissy
    bump!
    Member ian6375's Avatar
    Ian
    Glenelg
    Quick question; where does it plug into on the engine?
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    3 questions
    1. What size is the gauge?
    2. What is the size of the fitting/thread on the end?
    3. Have you ever used it?
    thanks
    J
    Iver never used the guage. Not sure on size of fitting, its pissing down outside and its in the garage. I know the light on it works. Think its 45mm.
    The probe mayt just screw straight into the thermostat housing or if not then get a alloy pipe that is a available at super cheap or burson etc that goes halfway in the top hose of your radiator. The fitting screws straight into it.
    Steve
    Um its an oil temp gauge not water.
    Will need to go into the oil pressure hole unless you can run an adapter with fittings for both temp and pressure.
    Oil pressure hole? Where?
    Julian
    Northern suburbs
    to fit it you can just get a sandwich plate which goes in between the block and oil filter
    Gl with the sale to bad its not a white series one, would have snapped it up to go with my set of omori gauges
    Steve
    Quote Originally Posted by Ksevn-T View Post
    Under your exhaust manifold towards the front of the block. Oil pressure is already there, about 2-2 1/2" diameter silver. Or as mentioned, an adaptor block between oil filter and block
  1. Vic. Omori tacho 10,000 rpm and omori oil and water temp
    By leo_palmer in forum Car Parts For Sale
    Last Post: 2nd November 2010, 10:18 AM
  2. oil temp guage
    By ke.slider in forum Car Parts For Sale
    Last Post: 18th October 2010, 01:04 PM
  3. 52mm Omori Water Temp Guage Wanted
    By ach_66 in forum Cars or Parts Wanted
    Last Post: 19th July 2010, 09:01 PM
  4. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  5. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
