Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 129
Thread: AE71 Haggard Wagon - Moonlight Garage's parts/tyre car ( R.I.P 1984 - 2012 - Gone Too Soon )
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default AE71 Haggard Wagon - Moonlight Garage's parts/tyre car ( R.I.P 1984 - 2012 - Gone Too Soon )
    Picked up a AE71 wagon today to be the new parts/tyres transporter and camper/fishing vehicle. I've been looking for a while for a Panel van or wagon for the right price, and got this one today.
    The car has very little rust (surface only really), few small dents, 4AC, runs, but blows oil smoke. It is a manunal 5 speed (T50). Car has 590,000kms!
    It shouldn't take too long to get it up to scratch. I will be fitting a 4AGTE motor, simple bolt in job (from my crashed gold AE86), wheels, and the body will stay haggard....
    It gets delivered in 2 weeks....
    At first, I was thinking the rear bumper had to go, as its massive and hideous, but then realized that since its a work/support vehicle, I can use it as a mobile work bench. I can attach a mini vice to it.
    CURRENT SPECS: (always updated)
    BODY/EXTERIOR:
    "Beater" style body. Has mostly surface rust from home panelbeating. Has a 5c bit of cancer in a rear guard, dents, paint marks, stickers etc etc.... Perfect beater look... Car has done 526,000kms
    Everything in the door window line painted black. Ie; Window frames, the bit between, plastic trim at rear.... etc
    Headlight eyelids painted black,
    Roof racks
    Replaced tailights with fresh ones
    Removed sound deadening in the rear
    Removed rear bumper
    Removed Front bumper
    MX73 front lip (slightly modified) on a horizontally chopped AE86 front bar
    Alluminium splitter and black mesh and indicators above the lip,
    INTERIOR:
    Genuine Luisi Steering wheel with a XT130 corona boss kit. It puts the wheel in perfect spot.
    Stripped rear sound deadening,
    Removed rear seat and seatbelts and carpet,
    Autometer tacho,
    Speco boost guage,
    AE82 Oil pressure guage,
    Saber water and oil temp guages,
    Microtech hand controller fitted to dash,
    SSCUS Front reclining bucket seats,
    Pioneer Stereo with remote,
    Battery re-located to behind passenger seat,
    ENGINE:
    4AGTE - AE101 4AGZE (supercharger removed)
    Microtech LT10s - Current tune (7/12/12) making 186kw @ 16psi
    Garrett GT28R turbo,
    440cc injectors (7MGTE),
    Royal Purple Oil (Have only ever used Royal Purple oil in this motor),
    Some braided lines and speedflow fittings where they need to be,
    4" custom dump pipe,
    "Racetec" turbo manifold (steampipe)
    AE86 Golpher Alluminium radiator
    KLS intercooler 450x300x76,
    9 row oil cooller with speedflow fittings
    Custom intercooler piping,
    Blitz Blow job valve,
    Oil catch can,
    Duel cam cover breathers,
    FUEL SYSTEM:
    Facet Pro-Flo external lift pump,
    Modified tank drain plug into a bottom feed,
    Bosch 910 main pump (380hp),
    surge tank,
    Aeromotive fuel filters,
    Using the 2 biggest standard lines (inlet and breather lines)
    DRIVELINE:
    W58 Supra gearbox and bellhousing (AJPS)
    Braided clutch line
    "Custom" Tailshaft (Used a decent size 1 piece I had from a KE20 with a 4Kturbo and later model KE Borg diff. Origin unknown. Just had to change the yoke to fit the W58)
    Standard AE71 wagon Borgwonka diff
    BRAKES:
    R32 skyline Non ABS master cyl with modified lines,
    Hopper Stopper big brake upgrade FRONT - Consists of AU XR8 290mm rotors and massive PBR calipers. Perfect for towing....
    Standard rear drums
    SUSPENSION:
    GReddy AE86 Front coilovers 8kg, GReddy AE86 camber tops,
    Strut brace,
    Superpro bushes,
    AE86 LCAS,
    AJPS 40mm RCAs
    Rear leaf springs now have the short/stiff leaf on top of the pack - Slightly lower and stiffer....
    ACT
    Compton
    Nice, where'd you pull this fine machine out of??
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Does this mean that the Limo is going to be put down ?
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    JoJo
    ACT
    Tuggeranong
    local guy.... Got it cheap...
    JoJo
    ACT
    Tuggeranong
    That would be ideal bob! but for now, I still need that for towing my boat......
    Aug 2010
    Geoff
    mt dandenong
    Nice one, going to tell us how cheap is cheap?
    JoJo
    ACT
    Tuggeranong
    500 biscuits.....
    Nice find and it'll be an awesome beast with your gold sprinters heart.
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    how much of goldys suspension will go into it?
    quit hatin get bakin!
    JoJo
    ACT
    Tuggeranong
    ^^ none really. It would be silly to put GReddy coilovers in a beater wagon
    Will get the rear leafs reset, and most likely just run AE86 front struts with shocks and springs....
  1. Replies: 13
    Last Post: 17th November 2012, 03:21 PM
  2. (VIC) AE71 Wagon. Wrecking whole car + wheels And Susp
    By tdk_rolla in forum Car Parts For Sale
    Last Post: 18th April 2012, 11:35 PM
  3. Replies: 1
    Last Post: 17th January 2012, 01:44 AM
  4. 1984 AE71 Wagon
    By blinded in forum Cars for Sale (Toyota Only)
    Last Post: 8th August 2011, 09:05 AM
  5. ae71 Parts new and used, ae71, parting out car
    By kombidrift in forum Car Parts For Sale
    Last Post: 10th March 2009, 07:20 PM
