Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: 4age not reving past 4000rpm
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default 4age not reving past 4000rpm
    hi, i currently have a problem with my 4age. its a jdm 4age bigport with tvis. i just put it in my ae86 and now it doesnt rev past or struggle to get to 4,00 rpm. motor came from a work jdm trueno. timing its all right, set at 10 degrees
    Nathan
    Lilydale
    sounds like the ecu may be in limp mode? i would start by checking the ecu for codes, then go from there.
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by Sprinter86 View Post
    Agreed with this.
    Do you know any history of the engine? i.e. has it come out of a mates car or is it fresh off the boat?
    Phuoc
    Liverpool
    motor come out of my jdm trueno. was running sweet. im gonna check plugs to see if they are fouled. how do i check for code on the ecu
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    id say check pins on TVIS plug, from memory mike86 had a similar problem, due to the fact TVIS kicks in yo!! at 4200, hope this helps
    Trev
    Queensland
    Redbank Plains
    Where you located?
    Reeece
    Casula
    Could be this or plugs are fouling at high rpm , causing engine to miss/drop cynlinders or run in limp mode
    Quote Originally Posted by MINIHORSE View Post
    Veteran Nikkojoe's Avatar
    Tom
    Sounds like limp mode. One possible cause is a map sensor fault. Check the connections to the map sensor (electrical and vac line). Simple test is to unplug map sensor and see if the engine stalls. If it stalls, map sensor is working fine.
    To check codes:
    If you have not got an engine check light on dash, use a test lamp. Find the pin on the 3rd ecu plug which corresponds to the check engine light. Connect one end of the test lamp to +ve 12V, the other to the check lamp pin.
    On the engine loom, the diagnostic connector on a zenki is near the a/c piping on the firewall. Its a little round plug with 2 pins (wire colours are blue/white(TE1) and brown (E1)). Kouki have a diagnostic box, but with more pins inside. All you need to do is bridge these two pins together (TE1 and E1) and then turn the ignition to on position. You will see the test lamp flash/check engine light flash. Have a look on club4ag website for list of error codes and what the flashes mean.
    Phuoc
    Liverpool
    i took out the map and it didnt stall, i have 2 map sensors 4age and 4agze and when i put them in they dont rev past 4000rpm and when i take them out they dont stall
    Nathan
    Lilydale
    get codes before you start muckin around changin parts IMO.
  1. 4age bt wont rev past 6500rpm at full throttle
    By matho in forum Technical - Questions
    Last Post: 22nd July 2012, 09:38 PM
  2. Car won't rev past 4000rpm - JDM bigport
    By Course_Out in forum Technical - Questions
    Last Post: 21st November 2009, 02:22 AM
  3. Blacktop with adaptronic not reving past 7k
    By Adsie in forum Technical - Questions
    Last Post: 2nd July 2009, 10:14 PM
  4. 4age wont rev past 4500rpm
    By bams_keto in forum Technical - Questions
    Last Post: 11th June 2008, 11:39 PM
  5. no reving
    By dog89 in forum Technical - Questions
    Last Post: 21st May 2008, 04:19 PM
