PS rack ends are a lot longer than manual, you might get away with it if you use longer tie rods. However I thought having longer tie rods would be enough on a manual rack only to find that I need RA60 rack ends which are 30mm longer.
Like the title says, am I able to run 0 toe in an ae86 with p/s with xt130 arms or will I need longer rack ends as well? I don't really want to put them in to check if they aren't going to be long enough and I have to do it all again.
Im running xt130 arms with a powersteering rack, no problems (plenty of adjustment each way).
Also had to change a rack end recently, a tercel has the same rack end as an ae86 with power steering (on a kouki from memory).
It will be fine
