Results 1 to 10 of 12
Thread: Bigport head differences?
    Senior Member JDM-086's Avatar
    Dario
    Melb
    Default Bigport head differences?
    Just trying to work out why this bigport 4age head is different
    I get the feeling one is a GZE head.
    If so what differences are there? this is for a future NA build so i want to make sure I use the right head.
    also whats up with those grooves??
    Moderator Sam-Q's Avatar
    Endeavour Hills
    those lumps are oil channels, got any more pics?
    Dario
    Melb
    nah but i can take more. any specific areas? i just took these as at a glance they were the only notable differences
    Veteran timbo's Avatar
    Tim?
    Wild West
    Top head is from an AE86 ONLY, it has no mount for FWD between the cams. Second has the mounts so it could be from anything, MR2 or Corolla. If it's bigport all you can do is guess what it's off.
    Dario
    Melb
    ok so the head with the 2 holes between the cams simply means it's a FWD/MR 4age.
    I'll have to speak to the previous owner.
    Apart from the cams are there any other differences? how do i ID the cams?
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I have heads lying around that are like what you have aswell....
    Tim?
    Wild West
    Cam's you would have to measure, unless you pull them out of a stock motor!
    Dario
    Melb
    this might sound stupid... which parts do i measure exactly?
    Tim?
    Wild West
    The lobes, tear drop bits. Google for the different lifts between big and small port.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    bigport is slightly more agressive, throw them in a smartport head
  1. 16V and 20V head gasket differences ?
    By t-nol in forum Technical - Questions
    Last Post: 28th September 2013, 01:31 PM
  2. Bigport head
    By d1staz in forum Cars or Parts Wanted
    Last Post: 23rd October 2012, 04:21 PM
  3. Replies: 6
    Last Post: 15th October 2012, 06:02 PM
  4. Bigport Head/ Bigport Engine Briz
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 18th January 2011, 01:28 PM
  5. Differences between n/a bigport head and gze bigport head
    By Course_Out in forum Technical - Questions
    Last Post: 5th April 2006, 01:52 PM
