Results 1 to 7 of 7
Thread: 15/16th Master Cylinder to ADM Booster
    Sutherland
    Default 15/16th Master Cylinder to ADM Booster
    Hi Guys,
    I know this has been covered in various threads but am struggling to find any consistency in the information.
    I have an ADM Booster and want to go to a 15/16 or 1 inch bore MS and want to know my options.
    The Nissan BM44 appears to be the easiest solution due to the built in bias valve but what is the difference between the ABS and non ABS models?
    Also where can I buy a new Booster and Master from thats well priced?
    Any help would be much appreciated.
    Cheers.
    Veteran johl's Avatar
    Johl
    the difference is i believe the abs model has an extra outlet on the master for another brake line. i bought my r32 non abs master and booster together from jdm garage for $100. with a slight massage the booster fits fine
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    Hey mate, Im running a s14 abs bm44 M/C on an ae86 with drum brake rears and hilux disc fronts.
    It fits up great and you will only have to make two new lines being a twin outlet and using the stock brake line manifold thing that splits the front into two lines.
    As far as the operation tho, I am having trouble bleeding the system, but im hoping its due to the brakes lines sitting around off the car dry as a bone for a year.
    So having said that is not very useful info but if you decide to use it, J.A.K motorsport in campelfield victoria sell them for $50 pick up
    Mark
    Im running a pajero mastercylinder with rx7 calipers and t18 drums, works perfectly, bolts up nicely. Only issue I found is that the 2 ports have a different flare on them, So one works with your standard line the other line needs the end changing
    Sutherland
    How did you change the end? Re flare it or step the line up to a different size?
    Thanks everyone for the input
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I have used the R32 NON ABS Master cyl in 2 of my 86's. Cheap, direct fit, Has a good pedal feel with various brake setups...
    Mark
    Quote Originally Posted by wideslider View Post
    I took out the shortest line and took it and the paj mc in to my local abs and said can I get this end changed to suit this and this end keep the same. It took a couple of tries cos my local store is a bit retarded but got it in the end!!!
  1. adm brake master cylinder - aftermarket options
    By skit in forum Technical - Questions
    Last Post: 3rd November 2010, 10:54 AM
  2. WTB ae86 brake booster/master cylinder QLD
    By Beetle in forum Cars or Parts Wanted
    Last Post: 3rd August 2010, 09:19 PM
  3. WTD, 4AGZE outlet, cat, and ADM master cylinder
    By bunkyskids in forum Cars or Parts Wanted
    Last Post: 7th June 2009, 02:22 PM
  4. ae86 brake booster and master cylinder
    By riojin in forum Cars or Parts Wanted
    Last Post: 3rd October 2007, 06:37 PM
