Results 1 to 6 of 6
Thread: The 4age powered Toyota 86
    Default The 4age powered Toyota 86
    Unfortunately it is just someone with some pretty average photoshop skills...
    The FA20 is a great NA engine which has unfairly received allot of hate from the Toyota purists. When asked why the hatred is present, most respond by saying the low power output and a lack of the turbo which subaru have been renowned for producing in the WRX range for the past decade.
    Would the same response be given if the Toyota 86 had received a sportier version of the 1.8L 2ZR-FAE found in the 2012 model Corollas? If past history is anything to go by i.e. the under powered Toyota paeso the answer is "YES!"
    Though I do anticipate someone somewhere will eventually will be dropping in a 4age, though getting it to pass the emissions tests will be somewhat tricky.
    Steve
    My limited knowledge in this matter tells me you can go forward in engine yr of manufacture into older chassis and keep its emissions your sweet, but going backwards you need to either meet or exide the original engines emissions, something a 4age in a ZN6 wont be able to do.
    Correct if im wrong. But i believe its along those lines.
    Yeah you are right.. Might happen on the track though
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Formula Atlantic 4age
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    People who hate on Boxer engines, you ask why "because there a boxer" *clap clap clap*
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    ew why a bigport of all things.....
  1. 2AZ powered 86
    By LittleRedSpirit in forum AE86 Owners Forums
    Last Post: 12th March 2020, 08:58 AM
  2. MRT review Toyota 86 vs Scion FRS vs Toyota 86
    Last Post: 2nd December 2012, 08:19 PM
  3. Toyota motorsports NZ - Toyota 86 Build
    Last Post: 13th October 2012, 01:21 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
