Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: Back to the Basics - AE86, Stripped out, 4AGE, Grip/Touge/Hillclimber car - My 6th AE86 - Moonlight Garage
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Back to the Basics - AE86, Stripped out, 4AGE, Grip/Touge/Hillclimber car - My 6th AE86 - Moonlight Garage
    A few months ago, I picked up a shell which I really fell in love with...... I've never owned a white one, and I already had plans for a build, and I liked this shell more than the other spare shells I have......
    After always owning turbo 86's, I wanted to go back to the basics, as recently I've discovered its just as much or even more fun to drive the living shit out of a NA 4AGE......
    My plan was to build something very basic and lightweight to use for Hills runs, Hillclimbs and some track days (grip)....
    So, I picked up this shell from a nice chap in Shepparton in Vic..... The car had been sitting around for quite a few years, but the chassis and body is actually very good and rust free..... Its a 1985 model too. It seems to have keep its condition better that most...
    When I picked it up -
    How the car was -
    Had a smashed passenger door window -
    Nice front flares was a bonus -
    The firewall had a great big dirty hole where that someone had cut for a 20V ...... I welded it up and came up good -
    I cut the section out of a crash shell I had lying about -
    For the donor motor, I had a AE82 Bigport in my stocks that needed a new headgasket...... Changed the headgasket, New Gates Racing timing belt and tensioner bearing etc, converted to RWD, cleaned it all up etc, and it came up looking more acceptable -
    For a Gearbox, I had a JDM T50, new genuine gaskets, Hardrace gbox mount and fitted up a 6 puk clutch -
    JoJo
    ACT
    Tuggeranong
    I resprayed the engine bay and the car interior all white..
    Engine in and wired up, factory AE82 oil cooler, intake is a genuine Apexi pod filter and running a new set of TRD copy extractors with half 2.25 and then 2.5" exhaust with 2 hot dogs only (bloody loud -
    For suspension and steering, I have -
    REAR - HTS102R Tokico shocks (all round), 4.5kg rear springs, T3 adjustable panhard rod, cusco strut tower brace, standard swaybar, adjustable rose jointed lower rear trailing arms (adjusted to 4deg)
    FRONT - custom coilovers (HTS102R Tokico inserts), 30mm RCA's, AE86 power steering arms, QUAIFE quick rack (2.5 turns lock to lock), new rack ends, New Japanese 555 tierods, rose jointed strut brace, new Superpro LCA bushes, New superpro rack bushes and standard swaybar
    Fuel system consists of a JDM fuel tank, with a Aristo 2JZGTE stock intank pump, new flexible lines, new fuel filter (300zx) and Autometer pro comp fuel pressure gauge. Plenty of flow there.....
    I also fitted up Whiteline lights in the back -
    For the interior, its completely stripped out.... All it contains is a rear harness bar, 2 seats, Nardi steering wheel, a stock dash bare inner skin (all padding/covering removed) and 2 grey door cards.... Nothing else...
    I will post up a few more pics of it when I can...
    Here is a quick video after doing the timing after the first startup yesterday...
    I plan to keep making the car lighter by swapping to fibreglasss panels when and where I can. I am also building a higher comp N/A motor that with go in the car once its finished.
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    Haha, this is mad Jojo! Highly approve of the exhaust
    Nat
    Newcastle
    Sounds awesome man! Nice work so far.
    Timmy D
    North
    so much love for this car
    Raw and basic
    hows 86s are ment to be
    JJ
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I thought I recognized the name on the invoice for the tie rod end, light-weight and N/A is my idea for the perfect 86. Never had so much fun going slow.
    Looking really good. Surely someone needs to put a quota on the number of ae86's you own?
    But hey i can't talk.
    JoJo
    ACT
    Tuggeranong
    Yeah JAmes, so much fun..... And with the basically straight pipe exhaust, the noise is amazing... hahaha
    Aug 2012
    Jarrad
    east
    This is really neat as far as stripped out cars go
  1. Replies: 11
    Last Post: 12th May 2015, 12:30 AM
  2. JZS147 ARIS-TOW (Moonlight Garage)
    By maxhag in forum Other Toyotas
    Last Post: 25th August 2014, 04:22 AM
  3. Replies: 128
    Last Post: 2nd May 2013, 12:44 AM
