Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: 500hp 70 drift build
    Oct 2015
    Jayden
    Wa
    Woodvale
    Default 500hp 70 drift build
    Hey guys new to the forum, bought myself a 82 ke70 that had been converted to manual and had a bride drivers seat on a set of steelies, still in the process of gathering parts, bought a built fully forged sr20 that made 507hp on av fuel.
    i have a few questions and many more in the future
    - what steering/ front suspension set up is better?
    trying to decide between s14 front end with r31 lcas or go towards the ae86 setup with lengthened xt130 lcas, love to hear all opinions and point me in the right direction thanks (pictures will come later)
    S13 setup is aweful in my opinion compared to the ae86. Steering can bind and i'd strongly advise against it.
    For the most part, Kelway / JDI knuckles with a lock spacer will give you more than enough lock. A descent set of ae86 coilovers will see it handling pretty damn good.
    What is AV fuel?
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Aviation fuel otherwise known as av gas. Leaded. The power it has achieved "should" be replicated using E85 with a suitable fuel system.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Post up some pics of the car... Looking forward to seeing it out on the track
    Oct 2015
    Jayden
    Wa
    Woodvale
ID:	36040I'll get some better pictures tomorrow, I will be tuning it for e85, I have all my fuel system nearly.
    bosch 044 and still need to figure out a surge tank underneath the car as I am planning to license it.
    Veteran AJPS's Avatar
    Lonsdale
    i have an under car surge tank for sale, pm me
    User fantapants's Avatar
    Pat
    s13 front end can be a reasonable upgrade if thought about and applied properly. unfortunatley most corolla guys throw it in and expect it to work like apples and give it up as a shit job...
    06/07/2011
    Oct 2015
    Jayden
    Wa
    Woodvale
    What would be a ideal front end setup? Any suggestions appreciated
    Oct 2015
    Jayden
    Wa
    Woodvale
ID:	36069Click image for larger version.
    little update, ive decided on shockworks coilovers they are the better setup to run acording to a few people over the bc's.
    tommorow im picking up some ae86 ps knuckles with ackerman adjustment and shortened aswell as a lock spacer.
    here are the specs of my motor and some pics to follow.
    - 2l sleeved
    - eagle rods
    - wiseco forged pistons, file fit rings
    - acl bearings
    - hks style pump
    - hks head gasket
    - solid lifters
    - tomie 270 procams and gears
    - 5 angle valve job
    - 6 boost manifold
    - garret gt3082r turbo
    - 3.5 dump pipe
    - 45mm progate external wastegate
    - greedy copy intake plenum
    - 73mm hypertune throttlebody
    - microtech lt10s computer x4 igniter
    - 044 pump
    - hks twin plate clutch
    - rb25 gear box
    hopefully get my coilovers ordered this week.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    You might want to run 2 044 pumps if using E85 and making 500+hp........ That is going to need alot of fuel delivery.......
  1. ke-70 13bt build
    By Turkish-86 in forum KE70 / AE71 Owners Forums
    Last Post: 6th May 2012, 07:26 PM
  2. Brendon's drift 70
    By thr55t in forum KE70 / AE71 Owners Forums
    Last Post: 20th December 2011, 09:34 PM
  3. Ke 70 Unfinished Project Drift track car
    By freak in forum Cars for Sale (Toyota Only)
    Last Post: 7th September 2011, 09:13 PM
  4. Japanese ke 70 drift pigs..Videos
    By 24 yr old Two door 86 in forum Toyotas in the Media
    Last Post: 11th December 2007, 08:37 PM
  5. DrIfT SpEc 70
    By rOlLa DrIfTeR in forum KE70 / AE71 Owners Forums
    Last Post: 15th January 2007, 07:01 PM
