I might be looking at it this afternoon and see if I can find what the problem is. The only thing really dodgy on this 4age install is the loom, and from what has been explained to me it's most likely the cause.
Dave, the loom is pretty fucked. It really needs to get taken off and remade just to eliminate it being a possible problem.
New loom is easier.
me and dad will check all through the loom this weekend,
if there are major problems ill just throw it out and start fresh, looks like shit atm only because none of the accessories are hooked up like tacho and what-not.
if I could trade kids for cars, I'd be turning the little critters out one every nine months.
ah k
good luck with it hey, let us know how it goes.
- Blaise Pascal
Having seen it now, loom is pretty munted i would say. Will try and hook up my ae82 loom to it and see if it works.
were gonna run a crow across all the sensor lines to see any interferance,
gonna run individual negative wires back to the ecu before buying tom's ae82 loom
although it does look very nice and has better injectors than mine and all of the plugs![]()
dude, It's CRO (cathode-ray oscilloscope).
lol woops?
i was typing really fast as im ebay-ing at same time
but yeh will try this and if it still dont work then bring on the ae82 loom![]()
found the problem!!!!!!!!!!!!!!!!!!!
unplugged one of the injectors and revved it and it runs perfect
the enjectors didnt have resistros on them so they were pulling too much from the ecu and the ecu just blanked out
kinda confused with that as early bigport injectors are high impediance and did not use/need any resistors to work. But if it's working for you then thats good
edit: looked again and found bigport injectors were 2.0Ohm low impediance, and later bigport (pink) were 2.7ohm.
