Pulled this out of my white 86 for a gze. Setup includes:
800km old JDM Bigport
Full rebuild inlcluding:
Reconditioned head
-sandblasted and cleaned
-valve stem seals
-valve clearances set
-machined/decked
Full new seals top to bottom
Smallport oil pump for increased oil pressure
Standard sized pistons
Block acid dipped, decked and honed
Crank machined with oversized bearings
Brass core plugs
New genuine waterpump and housings, FULL rwd setup as new
New timing belt kit
Still has 700km old oil included (mineral oil for run in km's).
Standard rwd primaries with custom secondaires
All metal engine mounts to suit
T50 (no shifter)
AE86 Zenki rwd loom with jdm 96kw ecu, map sensor, leads and coil with ignitor.
Only missing the flywheel, clutch and starter (but any 3/4a starter will work). Flywheel bolts and sandwich plate are included.
Price is $1600 for the lot. Can be installed and/or wired at an additional cost.
Located Perth NOR. May freight if enough interest.
Contact via PM or MSN.
Pictures can be provided, otherwise look at my build thread.
