Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 38 of 38
Thread: AE86 Fuel Tank into an AE71...?
  1. #31
    hmmm. well that is slightly different to the ae71... our stock filler neck and rubber is longer, so i cut the ae86 neck even lower, more than half off what you have there, victim if you have pics please post them up??
  2. #32
    ok update, with the ae82 cradle removed, and the filler neck removed, the tank fits. so we then put back on the stock ae86 cradle and it fits again, but the filler necks look a little misaligned, but i think that will pull into place with the rubber hose so i'm not worried. so now were going to run a stock '86 cradle with a in tank vl lift pump, and an external pressure pump and surge tank setup. does anyone have any suggestions for a cheap and easily accessible external pressure pump (preferably a quiet one) that will suit our 4age setup? (fresh motor, quads, maybe cams later, adaptronic)
  3. #33
    Veteran Nikkojoe's Avatar
    Tom
    Using the ae82 cradle on the 86 also causes clearance issues. I just manipulated the pipes a little and it fitted ok after.
  4. #34
    i may or may not have accidently broken the cradle a little in trying this haha. we're now going the vl pump route it seems with an in boot surge tank... anyone have any good quality in boot setups they want to share pics of?
    AND THANK YOU FOR EVERYONES HELP THUS FAR! it has been very much appreciated
  5. #35
    Veteran driftke70's Avatar
    Ryan
    Buderim
    run an rb30 intank bosch pump, trim a little off the pipe that goes into the tank, slip it on, wire it up and your away. Ran this in my keto feeding a surge tank with no dramas, i hate all the facet and warlbows and crap, they all suck.
    my new setup runs a pierburg feed pump to a surge to a boch motorsports pump.
    wheelfriends.wordpress.com
  6. #36
    Gone
    Joel
    Picton
    Best combo for pumps right their!
  7. #37
    Jun 2009
    Ollie
    Has anybody tried just bolting on the ae71 filler neck onto the ae86 tank? Im sure it has been tried, and im guessing that its still in the wrong postion, or holes dont line up etc, i just havent ever seen that being ruled out as an option.
    Also Joel, it looks like in your photos (the middle one) that the tank is hitting the chassis rail. Is that just because you hadn't done the fuel tank straps up, or is it constantly sitting in that position? If so is that where the stock tank sits? I havent ever really looked under the car at my tank.
    Ollie
  8. #38
    Veteran Skylar's Avatar
    Ken
    KE70 tank neck:
    AE86 tank neck:
    Pretty sure that's where the tank sits. They have a piece of foam/rubber attached to the tank at that spot.
  1. AE71 fuel tank
    By anastasios in forum Car Parts For Sale
    Last Post: 13th April 2012, 05:11 PM
  2. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  3. Does a JDM AE86 fuel tank bolt straight into an AE71?
    By anastasios in forum Technical - Questions
    Last Post: 24th February 2011, 09:32 AM
  4. WTB, AE86 JDM style Fuel tank ( as in EFI Tank )
    By Lexsmaz in forum Cars or Parts Wanted
    Last Post: 1st August 2010, 10:20 AM
  5. AE71 KE70 Fuel Tank
    By KE86 in forum Cars or Parts Wanted
    Last Post: 5th June 2008, 11:21 AM
