Not the same.
How are the vac lines hooked up?
Hey Guys,
Just wondering if these two engines share the same Fuel Pressure Regulator, because my fuel pressure is decreasing when the car is revved and I think my FPR is fucked...
Not the same.
everything is hooked up correctly, 100% sure about that...
I've been told that the FPR's aren't the same but I could use a 4age one just to quickly test and find out whether my one is stuffed
Yeah, you could. Just make sure no boost is used though (ie unplug s/c)
Also by correct, the brown/red vsv is connected correctly right?
From what I recall, surprisingly, the GE FPR is set to a slightly higher pressure than GZE.
