Results 1 to 10 of 13
Thread: 4age Loom off JDM Bigport - No lengthening required!!
    Hugh
    Default 4age Loom off JDM Bigport - No lengthening required!!
    Hey Guys,
    Unfortunately I have been fucked around by another member with selling my engine package, so now I have to sell the loom separately.
    It was on my JDM big port, which means, it can go straight onto any 4age conversion and is already long enough to get into the cabin and doesn't need lengthening like other FWD looms do. Will plug straight in and work. Was running perfectly when it came off the engine, but I have now gone for GZE.
    Looking for $160
    Located in Sydney. Can post at buyers expense.
    Cheers!
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    So it was a fwd one that has been adapted to rwd?
    Can you show some pictures of neatness? Cheers
    Hugh
    No, it is a factory RWD loom, off JDM Bigport...I'll get some pics up soon when I get home..
    Veteran slydar's Avatar
    Dimitri
    and i will have every other party you will need off a rwd 4age soonish too, if any interested members wanna pm me.
    78's
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    hey man, if this definatly plugs straight into a smallport then i'm interested
    bursting ovaries since 92'
    Hugh
    you'll have to do some searching if no-one confirms it in this thread as I'm not too sure. I assume IF it doesn't it would not be hard to get it to plug in...someone will know better than me though
    yes it will be a direct plug in for a rwd engine
    Hugh
    stock RWD? Would it work on a smallport converted to RWD?
    Veteran slide86's Avatar
    Huw
    Hills
    the injector plugs and TPS plug are different, are they not?
    i think ive come across this problem when doing a conversion before.
    Veteran Nikkojoe's Avatar
    Tom
    then the plugs on the rear water sensors are different aswell.
    Need to run a bigport dizzy too.
  1. JDM 4age Bigport loom questions
    By Matt in forum Technical - Questions
    Last Post: 2nd January 2012, 08:39 AM
  2. Jdm 4age bigport loom
    By Savtec in forum Cars or Parts Wanted
    Last Post: 14th February 2011, 02:27 PM
  3. JDM bigport engine loom + ECU
    By sundee in forum Car Parts For Sale
    Last Post: 11th September 2009, 11:03 PM
  4. JDM BIGPORT LOOM & AFM
    By loc33e in forum Cars or Parts Wanted
    Last Post: 12th September 2008, 04:02 PM
  5. Replies: 6
    Last Post: 22nd May 2007, 11:37 PM
