Results 1 to 10 of 17
Thread: Oil change -> Oil leak problem
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Default Oil change -> Oil leak problem
    Changed the oil today. All was fine.
    Changed the washer on the inside of the sump plug bolt as well. Tightened it up good and proper, but now it leaks. Small drops at a time, but it leaves a decent few drops on the ground after a while. The bolt is not stripped and wasn't/isn't over-tightened.
    When it happened on my old motor, I eventually took it to a mechanic, who said it wasn't tight enough. I know thats not true. Surely there's a reason why it's now leaking? It wasn't before. And I really don't want to drain the fresh oil out to fix it. Especially as I'm out all tomorrow and driving 2 hours to go away next week
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
    Jonathan
    The washer has to be made of something soft. Like:
    plastic
    copper
    aluminium
    felt/ aluminium
    If either of the surfaces are not flat, you may still need some silicon.
    E-Famous (Remeber your roots)
    Throw some thread tape in there?
    Keating
    Caboolture
    Didn't have it before and it was happy, so I didn't think to put some on.
    There was a black plastic one when I took it off, and where I did the change we found a pack of the same ones. I put one on there. Maybe putting 2 on there might sort it? Or just some silicon around the outside would work?
    Thanks for the replies, no searching gave me answers
    Jonathan
    You never put 2 washers on.
    I dislike thread tape.
    1 new washer, and some silicon on the thread only if you are unsure.
    Keating
    Caboolture
    Thats going to involve pulling the oil out of the car isn't it? Silicone on the thread only, or can I be cheap, and cheat by putting it on the part its leaking from? Probably a silly question, but it would be a temp fix.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    if you don't wanna drain the oil park on a really steep hill and jack up the car almost vertical you shouldn't lose any oil but if any maby a little don't flame me its just a thought i had lol
    the dyno pull to 300rwkw
    Senior Member gaz20v's Avatar
    Gareth
    Lismore
    i have this issue, there is a small insentation on my sump at the drain that constantly caused me issues. What i found was a washer with a rubber o-ring in it called a dowdy washer. have a look here
    Works a treat!!
    Veteran Nikkojoe's Avatar
    Tom
    I had this problem, it was caused by the washer not being thick enough. Make sure the bolt thread does not stop before the washer starts...
    Senior Member resol's Avatar
    steve
    vic
    wrong washer perhaps? there are like spark plugs (the washers i mean), so you do them tight then and extra 3/4 turn? for the first time and that should do it. doesnt matter about the threads, as the washer does most of the sealing.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  1. oil leak
    By Fozz in forum Technical - Questions
    Last Post: 6th April 2009, 05:56 PM
  2. Serious 4AGE oil leak
    By Golberg in forum Technical - Questions
    Last Post: 21st July 2008, 12:22 AM
  3. Dizzy oil leak
    By wide s13 in forum Technical - Questions
    Last Post: 26th May 2006, 10:02 AM
  4. how to clean oil spill or leak in drive way?
    By johl in forum General Topics (No Technical Questions)
    Last Post: 18th April 2006, 07:50 PM
  5. diesel in your oil change
    By damo46 in forum Technical - Questions
    Last Post: 14th January 2006, 12:48 AM
