Results 1 to 10 of 12
Thread: So I Bought a 4AGE...
    Kieran
    Thumbs up So I Bought a 4AGE...
    Car -ae71 pano
    motor - 4ac soon to be 4age
    use - not daily but street driven
    problem - I bought a 4age but is missing a few things
    occurs/started when - I bought the 4AGE
    personal situation - want to swap the engines ASAP
    Okay, So I bought a 4age engine package. Its a smallport (has TVIS and black cam covers) and an ADM t50 to go with it. The problem is it did not come with a few things that are needed to make it run, those things being:
    -starter and mounting bracket
    -alternator
    -flywheel
    -clutch/pressure plate
    -also the belt that would go around the water pump etc.
    so my question is:
    "what can I use from the 4ac and t40 that I already have to complete the the 4age and what will I need to buy?"
    also "where would I acquire the parts I dont have but need?"
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    So its a smallport with TVIS???
    RWD mani???
    FTP.
    Veteran Nikkojoe's Avatar
    Tom
    If it has tvis, its not a smallport.
    Not too much you can use from the 4ac, you could use the starter and sandwitch plate (between the engine and gearbox).
    -alternator, find one on these forums, 7m also fit
    -flywheel, find one on these forums, 200mm would be the easiest to suit a bigport and try and get flywheel bolts and the bolts that hold the clutch plate on with it
    -clutch, buy a new clutch kit from a brake/clutch shop, probably a heavy duty clutch kit to suit an ae86 (adm). That way you get new pressure plate, clutch plate and throw out bearing to suit the gearbox.
    -belt, 5PK825 or 5PK830 from repco
    Kieran
    yeah RWD manifolds, on inlet manifold think it has tvis written on it, I'm a little confused atm dont have it in front of me
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    might just be a jdm bigport manifold ? pull it appart see if u got tvis plate between manifold and engine
    Veteran Skylar's Avatar
    Ken
    What you have is a red-and-black top engine, or cam covers at least. Smallports are redtop as in both both cam covers have red writing.
    They are a goofy bigport with 7 rib block and 42mm crank but 9.4:1 comp. ratio.
    Kieran
    ^^thanks that makes sense
    Had another look at it this afternoon and definately bigport. I was just confused because when i bought it i was told it was a smallport out of a late model jdm ae86.
    so knowing it is bigport now does that change the parts I need to get?
    Ken
    No. Maybe the belt length is different between smallport and bigport.
    todd
    there might be a t3 big to smallport adapter to use a proper rwd manifold?
    pictures will really help yo cauz
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    if it is out of an ae86 then it is a bigport. None of them came with smallports.
    Andy
  1. So I just bought an AE86..
    By AlexDadson in forum Technical - Questions
    Last Post: 31st May 2012, 09:28 PM
  2. Anyone bought anything from JustJap?
    By Ksevn-T in forum General Topics (No Technical Questions)
    Last Post: 22nd February 2007, 08:42 PM
