Results 1 to 6 of 6
Thread: r31 diff H/B cables
    Member adam_loves_hachi_roku's Avatar
    adam
    Vic
    hoppers
    Default r31 diff H/B cables
    hey ned some help agian guys
    putting r31 diff into my 86, dont know what to do about handbrake cables, will i need to use r31 cables or 86 or mod them both to fit type of thing?
    really need a hand with this i have no clue...
    thanks heaps
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    search butten is your freind theres been a few people with this convertion such as my self there is a thread somewere here
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
    adam
    Vic
    hoppers
    thanks man, i been seaching but i cant find anythig i may jus b putting in the wrong words or something soo annoying, could you give me any advice at all?
    Troy
    Gisborn
    what i did was use s series drum brake cables and the parts inside the drums the cable goes in cut the brackets up and welded them to the r31 calper h brake cables its more complicated ill have to find the post
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I was asking this question not long ago, Here's the link:
    I havent done anything yet, except get a set of S series cables.When I've got some time, my local brake specialist said he can do it if I supply him with both the AE86 and R31 cables for about $200....
    Hope that helps
    Regards,
    JoJo
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well seeing no-one else wants to answer and for future reference I will make an update. I have managed to adapt the unmodified handbrake cables, wasn't hard either, just took a decent amount of time. I chopped the curved tab off the drums brake pads where the cable hook and welded it to the caliper arm, spaced out the standard cable with a steel tube and then welded it onto the caliper. I did this for Adam the starter of this thread.
  1. Diff, tailshaft and handbrake cables
    By wideslider in forum Cars or Parts Wanted
    Last Post: 7th November 2010, 11:15 PM
  2. ST141 disk diff hbrake cables
    By hachi_dk in forum Technical - Questions
    Last Post: 9th January 2010, 03:25 AM
  3. Replies: 8
    Last Post: 24th December 2009, 05:46 PM
  4. F series Drum Diff - Handbrake cables?
    By Konakid in forum Technical - Questions
    Last Post: 10th December 2009, 11:29 PM
  5. hand brake cables for a hilux diff
    By lewwy in forum Technical - Questions
    Last Post: 8th January 2008, 12:52 AM
