Sorry got confused with the suby ones
I have played this game before with a gze crank pulley. there should be 2 threads tapped into the pulley either side on the main nut. I use a puller like this one.
But mine was for a mini flywheel that i modded a little. Buy a tool similar to this it makes the world of difference.
Someone else did this once, but failed. They snapped the tap off inside the sprocket, and munted everything else around it. They effectively ruined a 7A motor, which they then gave to me. 7A-FE bits for sale.
It's funny though, ive had a good run with 20+ 4a's removing this gear, however I have only encounted this problem when I got my 4agze this year. I think ill chuck up a pic of what it looked like after I was finished with it![]()
I have done the drill and tap method with success, makes the pulley off-balance but I don't think it would be anything to worry about.
Have also used the hot/cold method, heat the sprocket with gas torch (Map 1ltr Gas etc) and then cool the crank with can of CO2, worked a treat. Just need to be careful of fire ( if you spray first then heat second) , and overheating the main seal, but its something that you would replace anyway.
I can see this working really well actually. Must try next time.
cheers for the replys guys
yeah i have tried a few of those methods already and also have killed the pully! i just want the stupid thing off. ill igve the drill and tap a go first, its already dead so i might just cut it off as nikko joe sugested. its good to hear im not the only one having problems with this
any one got a spare pully they dont need?
JJ
I did this the other day, had a pretty stuborn pulley that wouldnt come off.
Drilled and tapped 2 holes failed so i just drilled the hole out bigger and cold chisel it till it splits.
was on a 3sfe tho, same shit different story.
