Results 1 to 10 of 10
Thread: Cant get car started!
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Default Cant get car started!
    Yo fellas,
    As you know i just done a blacktop 20v conversion.
    Its bolted up perfect, it cranks over but doesnt want to start. Its never been run in rwd platform and is running on a new ecu with a base map.
    Though i think i already have cut down to my problem and this being fuel, i dont think my fuel pump is working.
    Is there anyway i connect it or check to see if it is the case?
    todd
    unplug the feed fuel hose from the fuel pump. switch it on, and stand BACK pew pew pewpew pew pew pew fuel everywhere means winner.
    probably don't do that. but it might be a little bit funny.
    Jun 2009
    Damian
    lol todd u sooo funny
    todd
    is it an intank jdm pump or external VL or the likes?
    Jun 2009
    Damian
    jdm set up and pump
    Veteran biggo's Avatar
    Nick
    Noosa
    you have an adaptronic correct?
    you need to run the fuel pump via relay off one of the aux outs
    Veteran Nikkojoe's Avatar
    Tom
    Your fuel pump is still probably connected via the old FCOR right? If that's the case, it should start breefly but die straight away (fcor has two triggers, one from original ecu and one from starter motor wire - pumps fuel when cranking). The fuel pump wire will be a blue/black wire on the FCOR.
    Jun 2009
    Damian
    Fcor?
    Nick
    Noosa
    Fuel circuit opening relay
    Veteran Rice86's Avatar
    Richard
    Liverpool
    as above
    - check fuel pump is getting power and working
    - check and make sure fuel line in is going the correct way on the fuel rail and return is going out the correct way...lol i know first had
    dose
  1. started motor
    By pen15 in forum Cars or Parts Wanted
    Last Post: 24th December 2010, 09:11 PM
  2. My build up (not started)
    By damo46 in forum AE86 Owners Forums
    Last Post: 13th August 2008, 04:15 AM
  3. new thread started please delete
    By browneye in forum Car Parts For Sale
    Last Post: 24th January 2008, 09:03 AM
  4. Starting engine not started in while
    By grape_moosha in forum Technical - Questions
    Last Post: 24th August 2007, 11:50 PM
  5. I started a new job this week,
    By sprinterboy in forum Offtopic Discussions
    Last Post: 12th October 2005, 09:51 PM
