Car - ADM AE86 with smallport 4AGE
Problem - Vacum leak (whistling from intake side of engine) on acceleration, launch and low RPM load conditions. Also, used to cold start idle at 2500RPM, then never below 1000 when warm.
Occurs/started when - I got the car on the road about 6 months ago. I have just put up with it but it feels like its lagging and the whistle is pretty annoying. Plus, I'd like to have everything working correctly if I can.
Use - Daily, weekend cruising.
The intake manifold has been cut and shut at the ends. The welding is quite good and not porous. As a temparary compensation, I removed the IAC housing off the bottom of the throttle body, and made a new gasket with smaller passages. It starts, warms, then idles properly now just with a loud vacum leak. My main question is where do the pipes pointing forward under the throttle body (while in RWD format) go in a factory corolla sx? I am using the two coolant lines underneath, the top two pipes going forward, I have joined together and the bottom two are plugged.
Let me know what you think guys, cheers.
