jdm ae86 4age one or ady said to me his friends ke uses a paseo and its a snug fit so can try that
Car - ke70
motor - 4age
use - skids/daily
problem - throttle cable
what cable do i use as the stock one seems to be to way long
mereki.
~KEEP DRIFTING FUN~
ep91 starlet apparently work.
Some other ones that have wider hole spacing can be modified (the plastic mount holes slotted) to fit
You can wrap it once around the booster for a quick fix, then go for a more permenant solution like 4age ae86 or custom
Yep, I had a Paseo one installed on my 4AGE'd KE70. Came out of one of the models below,
Perfect length.. Felt like a normal throttle again
Was that completely bolt in from the paseo?
I've used an EP91 starlet cable, the outer sheath is a good length, but the inner wire is really too long.
ive got a JDM AE86 4AGE throttle cable if you want to fork some cash out for it
i moded a ae82 one 2 fit, works pretty well
mereki.
~KEEP DRIFTING FUN~
Yep, I just took it out from the paseo and then installed it in my KE. Didn't give me any troubles at all.
Previous ride: 4AGE powered KE70.
Current: JZX100 Chaser and '73 Datsun 240z.
http://twofortyzee.wordpress.com
