I know the differences between the two pulleys, but my question is:
can you use an aftermarket RWD under drive pulley on a FWD water pump?
i was thinking maybe the aftermarket item suits both applications? there should be no offset difference in the actual ribs that the belts run on between the two (fwd and rwd)
