as long as you can make a bracket(and belts etcetc) for the compressor and the lines match up you should be fine, and you have the wiring for the compressor to kick in
ok my first real day of summer driving in the hachi was not fun.
when doing to silvertop install i didn't keep the 20v aircon on the motor because of the different setup to the 4ac.
Is it possible to take the pully off the 4age aircon compressor and tranfer it to the 4ac one? or can the 20v aircon compressor be retrofitted to the 4ac setup?
If you have an 86, the 4ac compressor is the same as a jdm zenki 86 compressor bar the pulley. You can swap the pulley's over, but the bracket needs to change to rwd 4age a/c bracket (preferably with the tensioner for a/c only and not the bracket for a/c with p/s which has a seperate tensioner) and rwd 4age crank pulley as the outer pulley is slighty offset than the fwd one (belts wont line up properly - although you sometimes can get away with it).
