Results 1 to 2 of 2
Thread: 4age alternator pin out
    Kieran
    Default 4age alternator pin out
    Car - 71 pano
    motor - bigport 4age
    use - pretending to drive in the garage
    problem - loom didn't come with alternator plug so i dont know which way to wire it up to the main engine relay. also I have been told the alternator is from an ae93 smallport if that makes a difference and I have found an sv21 plug that fits but wires are different colours
    so basically i want to know which pin is which.
    occurs/started when - i am trying to wire up the alternator
    personal situation - wanna get it finished so i can do some skidz
    Veteran Nikkojoe's Avatar
    Tom
    quick search found this:
    ( B+ ) - Battery Post - Heavy gauge wire that connects to the battery.
    ( S ) - Sense - Used to sense voltage across the battery to prevent overcharging. Usually connect this to the battery post wire as it goes to the battery too (saves wire).
    ( L ) - Lamp - Alternator charge Lamp (Turns off when alternator starts charging).
    ( IG ) - Ignition - 12V Ignition Switched Source
    4ac voltage regulator on the strut tower has the lamp and ignition wires on that plug, so look for:
    Black with yellow - IG
    Yellow (or Yellow with white) - Lamp
    Connect the associated pins together and you are good to go
  1. 4age 20v ST- Microtech ecu - wiring / plug pin outs
    By Twisty92 in forum Technical - Questions
    Last Post: 23rd October 2015, 08:16 AM
  2. 4age alternator
    By Stej in forum Technical - Questions
    Last Post: 24th December 2009, 04:23 PM
  3. 4age alternator
    By tin can in forum Cars or Parts Wanted
    Last Post: 16th October 2009, 12:05 PM
  4. what size gudgeon pin is a jdm 4age?
    By fozz in forum Technical - Questions
    Last Post: 8th March 2008, 10:02 PM
  5. 4age alternator
    By cr86zy boy in forum Cars or Parts Wanted
    Last Post: 14th August 2007, 07:45 PM
