First pic, your sc outlet has been flipped upside down and welded. It's obvious 2 goes to 3, but the way its done is dumb. Instead of making cutting up and welding stuff or running a stupid hose for it, block both ends off and do the abv mod (which looks like its already been done in the pics). 1 Seems like brake booster hose.
2nd pic
? - for your Idle air controller, its missing. You will need it to idle properly (kinda).
pic 5
Goes to heater tap, but your aw11 outlet points into firewall so you need an ae92 gze/ge or later. (I have one here i can sell you minus the sensors)
Pic 6
Right outlet goes to heater tap, left goes to remote thermostat which you dont seem to have setup.
Check my 4agze developement thread in the ae86 members ride section (2nd or 3rd page), it will give you an idea how to setup the water.
Last pic, use ke70 throttle cable, its longer and suits this the best. HOWEVER, it doesn't have good adjustment on the thread because of how much cable the gze throttle body needs (you will know what i mean when you try it). To overcome this, slot out the bolt holes on the bracket to move it closer or further away to the throttle body.
