Phoc brah im sure local car stores can sort this out..
Car - ae86
motor - jdm 4age
use - air con
problem - no belt
occurs/started when - i have a 4age in my ae86, motor and a/c came out of jap 86 with power steering. i've now put the 4age and a/c in my car and dont want to run power steering, but the belt doesnt work on my car because it needs the power steering. if i bought another shorter belt, i cant use the tensoner because it doesnt reach all the way down and theres no other way to tension the belt
personal situation - if anyone has pic of 4age with a/c and no power steering can u please post it up.
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
dose
You can either get an a/c bracket for a/c only which has a tensioner built into the bracket, OR
What i did was buy a new ribbed pulley. I looked through a Nuline pullies parts catalogue until i found the pulley i needed (there was only one in the catalogue and it was from a nissan from memory). I then made the tensioner bolt to pull the belt up by welding a nut on it so it wouldn't fall down, you can still move the pulley up or down but you cant remove the adjusting bolt from the bracket now.
pics please nikko
i was just thinking. instead of having the tensioner pully can i get a 5puk pulley to replace it?
Pick up Sydney
Emails ignored
Texts ignored
Wankers abused
That's the only pic i have and can't get any more cause i sold the setup.
Pretty much what you said is what i said. I'll try and find the part no. for it because it was the only pulley with the correct ID hole size that had 5 ribs.
I think it's the EP097 pulley, from an R50 Pathfinder. Just double check the id of the hole is 12mm.
