Results 1 to 5 of 5
Thread: [VIC]: 4AGE Fuel Pump Relay
    Member khoala's Avatar
    Khoa
    Default [VIC]: 4AGE Fuel Pump Relay
    looking for a 4age fuel pump relay asap, if anyone has one call me on 0421152048, will pick up asap
    cheers khoa
    Veteran Nikkojoe's Avatar
    Tom
    There is no fuel pump relay for a 4age (4agze have a fuel pump relay, which connects to the fuel pump resistor to drop the voltage to the fuel pump at idle), rather a circuit opening relay (COR) to latch the fuel pump on cranking/when engine is running. You can just use 2 normal relays to replace it (with a few connectors).
    Otherwise other toyotas from the same era have the same relay.
    Elite rthy's Avatar
    Leo
    Tulla
    camry sv21 and celica with similar motor user the same relay that plugs in
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    this is true
    ~KEEP DRIFTING FUN~
    Khoa
    thanks for the replies guys, will be grabbing some asap
  1. [VIC] Borg warner diff + 4AGE Fuel pump
    By malk234 in forum Cars or Parts Wanted
    Last Post: 31st July 2012, 03:19 PM
  2. Fuel pump wiring - extra relay?
    By 70XIN in forum Technical - Questions
    Last Post: 15th June 2012, 08:48 AM
  3. Wire up my Alternator, Starter motor and Fuel pump relay!
    By DRFTAE86 in forum Melbourne & Vic Events and Discussion
    Last Post: 15th March 2010, 12:19 PM
  4. What kills Fuel pump relay's??
    By v-tec in forum Technical - Questions
    Last Post: 30th September 2008, 02:06 AM
  5. Fuel pump relay
    Last Post: 16th August 2008, 11:48 AM
